Torquing lug nuts?
Old Feb 8, 2017 | 01:31 AM
  #81
gpruitt54's Avatar
gpruitt54
Yep, 100 ft lbs is what they should be. When I and installed new rotors, I gorilla armed the lugs nuts and later went back and applied an air driven lug wrench, just to be sure I did it extra wrongly. Drove the car for a few weeks like that when I ran into a thread on this forum on the topic.
After going back the properly torqueing the lugs I noticed more feel in what the front tires were doing. Is that supposed to happen?
Old Feb 8, 2017 | 02:32 AM
  #82
BigStig's Avatar
BigStig
Old Feb 9, 2017 | 08:17 AM
  #83
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Back in the late 80's I worked at a shop that had a wheel fall off a car on a test drive. I also had customers cars that someone torqued the lug nuts so hard we had to use a breaker bar and a pipe to get off (not due to rust either). At that time I decided I needed to make sure I was close. I never torqued with an impact as I felt I had NO control with one other than super tight with good air pressure. I knew I would not take the time to torque lug nuts down for the rest of my life with a torque wrench so I practiced for a month or so with specific length breaker bar and then checking with a torque wrench until I was always very close every time. Since then I have never had a problem and none of mine have been too loose or too tight when taking the wheel off one of my personal vehicles 6 months or a year later for service. Good enough for NASA - nope. Good enough for me - definately yes.
Old Feb 9, 2017 | 10:34 AM
  #84
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
" didn't have the time "..?????? 20 nuts ...= 2 minutes to insure repeatability, and safety for the customer. . Also how could any shop not allow that extra two minutes. SOUNDS like thin soup to me.
There is no justifiable reason not to torque.
That excuse goes right along with "the dog ate my homework "
Old Feb 9, 2017 | 10:37 AM
  #85
Evil-Twin's Avatar
Evil-Twin
Why is it that there is never enough time to do it right, but there is always enough time to do it over.
Old Feb 9, 2017 | 10:58 AM
  #86
Toys4Life C5
St. Jude Donor '21
If I owned a shop, I would require a torque wrench when installing wheels every single time. One accident could eat up years worth of profits. It comes down to this. At 47 years old, I do not trust anyone else to tighten important fasteners, just me.
Old Feb 9, 2017 | 11:09 AM
  #87
rfn026's Avatar
rfn026
A bolt is really a spring that holds two things together. We all know what happens when you pull a spring too far. It never returns. Same with a bolt.
Richard Newton
Bolts 101
Old Feb 9, 2017 | 11:11 AM
  #88
Evil-Twin's Avatar
Evil-Twin
I'm right there with you.. No one can do as good of a job or have the same amount of focus that I do when doing anything.
I was blessed with gifted hands, a good education, and the ability to be analytical. However, I'm not so self absorbed that I would not choose to rely on experts when necessary. Problem is that its tough to find a qualified expert.
There are a lot of self proclaimed experts out there but in reality, There are a lot of Hacks out there. I'm not willing to subject my safety and that of my family to a hack. People who brag that they are so good, they don't need to follow procedures, or use those tools and test equipment to insure a quality job. Or that they don't have the time to do it right.
Old Feb 9, 2017 | 11:20 AM
  #89
Widgeon5's Avatar
Widgeon5
Though I will continue to always use a torque wrench, your procedure is not totally unreasonable. Question: Do you periodically recheck the calibration of your arm?
Old Feb 9, 2017 | 11:38 AM
  #90
Evil-Twin's Avatar
Evil-Twin
Since every bolt or nut has different characteristics of engagement. it is impossible to " feel " that variance without a point of reference. There is a reason why there is a torque spec.. that why they sell torque wrenches, and that why procedures are in place to do it right.. Since these self proclaimed expert never use a torque wrench and since lug nuts are not the only thing they tighten.. how do they dial down or up their feel..? They Don't... they just wing it.. and since Ive already done the testing in the field, I find that most techs who own a torque wrench but never use one, over torque not under torque.. and as much as by 30 %.. and they have stretched the threads beyond their designed stretch. the next time that nut or bolt is tightened using the same logic and over torque, that nut is now at the point of fracture.. all because the tech was a self proclaimed expert, a know it all, lazy, did not have the time, a hack, or all of the above.
Old Feb 9, 2017 | 11:45 AM
  #91
Evil-Twin's Avatar
Evil-Twin
Some of the people here on this forum claim to have worked at a dealership for 25 years, and never used a torque wrench, they were above that.. Hacks like this are the reason why I always say " Be careful who you listen to here"
There are also some really great people on this forum who dot their " i " 's and cross their " T " 's. People who know the value and pride of doing a job right.
Old Feb 9, 2017 | 01:25 PM
  #92
danh52's Avatar
danh52
decided to go elsewhere
Old Feb 9, 2017 | 02:08 PM
  #93
rfn026's Avatar
rfn026
Wow - You certainly don't see this stuff happen on CF too often.
Thank goodness.
Richard
Old Feb 9, 2017 | 02:44 PM
  #94
Quickshift_C5's Avatar
Quickshift_C5
I always torque to spec. Always.
All these guys who just torque it to anything or use a gun to just zip it on explain why I got home one day after taking my BRZ for a simple tire change and couldn't get the lug nuts off as easy as usual. They had torqued the damn things to over 130ft-lbs with their impact gun without a care in the world.
The torque spec is only 89ft-lbs.
I never take my cars anywhere any more. I can't recall one single time I've ever been to a shop and came home without a problem, however minor it may have been. Having the shop change the tires was the last thing I had them doing besides alignment. Now, I just haul over the wheels and tires and ask them to mount and balance and I go back home and put the wheels on myself...
Old Feb 9, 2017 | 03:07 PM
  #95
doublec4's Avatar
doublec4
Although this video addresses anti-seize on lug nuts, it shows you how you have a certain torque range to work within for a given fastener. Also lists some possible consequences if you over torque or under torque.
Old Feb 9, 2017 | 03:11 PM
  #96
Vette_DD's Avatar
Vette_DD
https://www.corvetteforum.com/forums...conflicts.html
Online Conflicts
For the most part, the CF community remains a friendly place where ideas, thoughts, and assistance can be found. Unfortunately, there are times when members forget that this is an Internet forum and issues between members can get out of hand. This includes members turning to the forum to air a personal offline/on-line problem which results in sides being drawn by participating members.
In these situations, it is the forum's role to expeditiously end any conflict for the good of the forum and its membership. The forum's goal is not only to remain family, work, and corporate server safe, it also will not serve as a battleground where offline/on-line personal matters and drama are permitted to be played out in front of other members.
Any thread(s) that contain open bickering, name calling, subtle derogatory messages, "digs," personal attacks, or anything negative in nature will be closed/edited or deleted, and any participating members who post in violation of this rule, will jeopardize their posting privileges.
If any member is being harassed on-line in a thread or privately via PM, they should avoid a confrontation with the offending member and immediately report the problem to a section Moderator via PM, or by clicking on the "report post," icon under their user name.
The Moderator will evaluate the issue and take appropriate action to rectify the situation.
