Torquing lug nuts?
The proper way is to torque but the reality is that %90 of the vehicles out there on the road are torqued by feel and they are doing just fine. Like the engineer said everyone he tested over torqued so the possibility of a wheel falling of is quite slim. The worst case scenario is you may have to replace lugs and studs from thread damage
It is simple to avoid this with a 2 minute torque sequence.. Its simple to do. People who avoid this, will pay for it in some way..
As far as all those thousands of people who don't, they are the ones who need tires, brakes, rotors and alignments more often then those of us who take the correct steps to maintain.
My car has 100,000 miles it has had the original set of brake pads, that lasted 70,000 miles and the present set. it had the original rotors which are still perfect, in a box, that I replaced at 15,000 miles . Only because I wanted bugger rotors. they have 80,000 miles and they look better now then when they were new. I've had one alignment in 18 years. I've never had an issue with tire wear. Sold my original Run flats, and wagons with 30K on them for 800 dollars. Bought CCW with Michelin pilots ran them for 12 years and put 60,000 miles on them and sold them for 2200 dollars, with no uneven wear.
People who know what is the right way, and still don't do it, are just lazy or stubborn. there is no effort, so why not do it..
It people who use street logic ( millions of people get their wheels put on at a shop where they gun them on. ) those same people go back to those shops for tires, rotors, alignments. I've never had to rely on a shop for anything but a single alignment.
Bill aka ET
Also what do race teams do about torquing lug nuts? Are their pneumatic tools able to predetermine the proper setting. I would think a wheel on a car at running 200 mph would require some pretty precise torque settings to ensure no wobble.
Bill aka ET
No arguments, anyone can do what ever they want to their car.. its has no effect on me.
I'm just offering good sound procedural advice. That's what I've been doing here for the last 16 years. Offering logic, facts, options, etc.. never holding a gun to anyone's head. Being informed is a good thing... having alternative points of view.. is also a good thing. People can make up their own mind if something is note worthy, or just hype.
Bill aka ET
Those without viable facts to support their claims, they always seem to get their panties in a bunch. When someone offers facts to support their claims, those with empty claims feel its an argument.
Bill aka ET
Now, I have to ask. A month or so ago, in another thread about the age of tires, you castigated me for selling my original 4,000 mile Z06 tires to a dealer when I bought new ones. Thoroughly chastened , I began to feel bad about my decision but not enough to return the four hundred dollars I received for them.
Today, as a self professed expert who never posts about anything you are not an expert on (your words!), we learn you sold somebody a twelve year old set of tires with 60,000 miles on them. While I have tremendous respect for your mechanical knowledge and opinions, please tell me I need not be concerned about your sincerity. Or, is this a classic case of what is good for the goose is not necessarily good for the gander!
Its always nice to see people try to dissect what I say in an effort to somehow discredit me.. IM here on Very borrowed time. trying to keep my sanity. So thanks for the kind words...
Bill aka ET
At the moment I am in remission taking poisons in a clinical trial program which has been physically devastating but on the other hand IM still alive.
Anyway, yesterday I ordered a torque wrench for tightening my lug nuts at the 100 lb measurement suggested by many. Thank you all for your suggestions.
Many of those same people will say its ok to use regular fuel in their high compression engine on a regular basis because its says you can use regular in the event that premium is not available. Same with using Dino oil that says 15,000 miles.. and they will run 15,000 miles even if it takes 3 years to get there. they don't have a clue that this engine runs hotter by design and requires a specific heat additive to the synthetic oil. Its a spec that was given to this engine design in a Y body frame. Too many people think this is their grandfathers Buick, and use 1960's thinking to say, its not necessary. my grandfather was a mechanic for 40 years and that's the way he did it.
that type of thinking was the main reason that it was common knowledge to get ride of a car before it hit 60,000 miles. With so many C5's and LSX motors runni8ng strong at 200,000 , 300,000 and 400,000 with no internal issues when properly maintained, its obvious that 1960 thinking no loner applies.
Bill aka ET
Torqueing is something anyone can do... Many enthusiast want to be pro active with their car and just need a little direction and confidence.
Bill aka ET
No question--torque to spec or lose a wheel and worse.
On the street it's the same.
Good luck and keep them tight.
Not trying to be a dick as I have had a case where I needed 350 ft-lbs torque which my impact gun can generate (max rating is 450 ft-lb) but no clear way to ensure I put 350 to the fastener.
In applications where weight is of great importance, such as aircraft, torque values are critical. The engineer will choose materials and fasteners that just meet the strength requirements, but no more. If a fastener is under-torqued the assembly will not have the required strength. If it is over-torqued the fastener is closer to its failure point and again the structure will not have the required strength. With road-going cars, engineers have the luxury of building in extra weight and strength. They have always done this with wheel studs, realizing that over-torqueing is a fact of life. (I don't know, but am guessing that even race car designers give away a little weight here to allow for 12-second pit stops.)
Having said all that, I am OCD about doing it correctly myself.
