Torquing lug nuts?
Thanks for your comments.
Hope this helps
Bill aka ET
The idea of torque, is to " stretch " the thread of the major pitch diameter of the stud, to the minor pitch diameter of the lug nut, to a predetermined force ( torque spec ) that will not compromise the integrity of stud or the lug nut... too much force will fracture the integrity of the thread., not enough will not add enough stretch and the nut can loosen.
I've been a Hands on automotive engineer for 40 years and a 4th and 5th year engineering co-op teacher in the GM coop engineering program . I torque everything. especially critical with aluminum alloys. GM teaches torque compliance as a requirement... I subscribe to doing it right . I've tested GM techs in the field who think they know it all.. and found that most techs over torque by as much as 30 %..
You can be a world class mechanic and do it right, or you can be a halfassed mechanic and wing it.
Proper installation requires torquing wheel-attaching hardware (lug nuts or bolts) to the recommended specification for the vehicle make, model and year. Torque specifications can be found in the vehicle's owner's manual, shop repair manual, industry reference guides or obtained from the vehicle dealer.
Proper torquing requires using the correct tools, procedures and patterns to prevent over-tightening hardware, stripping threads and stretching studs, as well as will reduce the possibility of warping brake drums, brake rotors or suspension hubs.
Under- or over-tightening wheel-attaching hardware can be damaging and dangerous.
Torque specifications are for dry threads only. The fastener threads should be free of oil, dirt, grit, corrosion, etc. The hardware should turn freely without binding when tightened by hand. It is important NOT to lubricate hardware threads or seats. The friction at which torque is measured against should come from the hardware seats. Lubricating hardware threads and seats alters the friction generated at the lug seat which will result in inaccurate torque readings and/or over-torquing of the hardware.
We recommend starting hardware by hand, snugging them manually and then using a beam or click-type torque wrench to apply the final torque and confirm the recommended torque value has been reached.
We do not recommend using impact guns or torque sticks when installing wheels.
Impact guns deliver torque as torsional impacts, made by internal hammers. Delivering torque as torsional impacts can damage hardware and wheel finish. Some vehicles, such as Porsches, require the use of special sockets to tighten the hardware without damaging their anodized coating.
The proper application of a torque stick requires the use of a lower valve torque stick than the vehicle's specified torque setting first. Only then should the hardware be tightened to the final torque setting using a beam or click-style hand torque wrench. Often this critical step in the procedure is overlooked and the result is inaccurately applied torque on the hardware.
Some of the variables that can cause inaccurate torque delivery:
Type of impact used (air, electric, cordless)
Power (air pressure, air volume, length of hose, size of fittings, battery power, battery age)
Impacts per second
Size of internal hammers
Possible use of additional adapters
Socket size, weight, length
Operator grip strength
Weight of the impact
Applied angle during use
Attempting to fully tighten hardware with impact guns/torque sticks also prevents using a click-type torque wrench to confirm the specified amount of torque is present. While a click-type torque wrench can identify when the selected torque has been reached, it cannot diagnose excessive torque.
Once you have the right tools, use the appropriate crisscross sequence (patterns shown below) for the number of the vehicle's wheel-attaching hardware positions until all have reached their specified torque value.
Tightening and Loosening Patterns
New wheels should be re-torqued after the first 50 to 100 driving miles.
This should be done in case the clamping loads have changed following the initial installation due to the metal compression/elongation or thermal stresses affecting the wheels as they are breaking in, as well as to verify the accuracy of the original installation.
When rechecking torque value, wait for the wheels to cool to ambient temperature (never torque a hot wheel). Loosen and retighten to value, in sequence using the torque procedures listed above.
Today's lightweight wheels are made of alloy's that can't take the same abuse those older wheels did and it only takes a few extra minutes of your time to do it correctly. I still take mine off w/an electric hammer drill but I install them by hand tightening, torque to 70 FT LBS in a star pattern and then to 100 FT LBS in the same manner. You'll never have an issue with this type of install.
Most Techs that I told to follow GM procedures, where not happy, and when told it could effect their job status they were even more upset, because doing things right meant it would take more time and thus make less money.( one of the reasons GM dealerships and " The Dealership " at Large " get a bad rap. too many prima donnas not enough qualified techs Plus a lot of Tech are unwilling to follow procedures... a very negative employee trait. Noted in their employee jacket. and subject to a build history to terminate.
There is only one way to do something right, and it does not include winging it.. this isn't 1960 , and no one is OLe Dave who has been a mechanic at the Buick dealership for 40 years. The dealership cant wait for Ole Dave to retire.
No one " wings it "in the military . Half of my character is bases on military principles learn while serving. I still use those principles today.
Bill aka ET
And for me... the extra time it takes to assure that I'm achieving proper torque spec is minimal. I've never been in that big of hurry where I needed to "skip" that step.
If everyone agrees that torque specs are given in every repair manual offered, and that these specs have been tested and recommended using the most scientific stress to fail test instruments. Will they also agree that anyone who does not use specific torque specs and procedures are just too stubborn, too lazy, or just a self proclaimed Know it all.
I would love to hear the logic of any of these " know it all's " that say torqueing to spec is a bad idea. It reminds me of my Father saying micro wave ovens give you Cancer. Or Computer are just a fad. And if you have a wireless phone you are just a show off. Just a person living on the past, and unwilling to accept, the old ways are " "OLD " and there are better ways, safer ways, more acceptable ways, correct ways.
This is the reason why some people have a well maintained and documented car and can command a high price, and other do a half assed job and wonder why their car is not as valued as others.
