hurst shifter
Old Feb 10, 2017 | 04:30 PM
james2828's Avatar
james2828
Cruising
Default hurst shifter
2004 c5 with 20,000 miles I installed a hurst shifter and it's rattles in 3rd at 4-5000 rpm and it not that easy to get into gear.
Has only one else had this problem and how was it repaired??
Old Feb 10, 2017 | 06:21 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Did you purchase the shifter "new", and if so, did you follow the instructions, with respect to the "stop screws"? Also, did you make sure the "neutral gate" is adjusted properly?
Old Feb 11, 2017 | 03:01 AM
striper's Avatar
striper
I had the same problem. I called Hurst and they actually told me that's the way they are and there is nothing they can do to fix it, they all do that eventually. So I got rid of it.
Old Feb 11, 2017 | 04:21 AM
chasboy's Avatar
chasboy
Oldtimer
Jeff, I was going to say that a friend of mine with a Z06 was unhappy with his! Oh well, you beat me to it!
Old Feb 11, 2017 | 07:28 AM
leadfoot4's Avatar
leadfoot4
Whereas I've had mine in my C-5 for 15 years, and am totally happy with it.............
Old Feb 14, 2017 | 09:30 AM
james2828's Avatar
james2828
Cruising
I'm not happy with the Hurst shifter which shifter would be the best replacement ?
Old Feb 14, 2017 | 10:59 AM
MGW shifters get very good reviews here on the forum. Some owners go with the C6 Z06 shifter as a replacement.
Old Feb 14, 2017 | 02:33 PM
Mrg60's Avatar
Mrg60
Love my Hurst, I did do the Anti-Venom Mod. Made a difference, much easier to run through the gears. One washer used.
Old Feb 15, 2017 | 09:40 AM
james2828's Avatar
james2828
Cruising
anti-venom mod??? please explain ... I would much rather fix what I have then spend big $ on another shifter
Old Feb 15, 2017 | 09:52 AM
knewblewkorvette's Avatar
knewblewkorvette
Here you go:
https://www.corvetteforum.com/forums...venom-mod.html
Old Feb 15, 2017 | 09:58 AM
knewblewkorvette
Real cheap, real easy.
Did it with my B&M ripper shifter and it helped some. Still didn't like the shifter so went with a C6 Z06 shifter in my 98, currently installing a MGW shifter in my 02.
Old Feb 15, 2017 | 10:18 AM
02BlownZ06's Avatar
02BlownZ06
I just had the B&M shifter installed in my Z and I REALLY like it! I have not had experience with other aftermarket shifters and I know it seems like a majority on here prefer the MGW but I have no complaints with the B&M. Shifting is precise and a lot more fun than the stock shifter and the B&M isn't too bad on price ($250) Just my .02
Old Feb 15, 2017 | 11:00 AM
Patches's Avatar
Patches
I have an MGW in both my C5 and my C7 and they rock. IMO, no better shifter for the Corvette out there.
This one for my C5
And this for my C7
Old Feb 15, 2017 | 12:57 PM
leadfoot4's Avatar
leadfoot4
I have to ask, since you didn't seem to respond to my question.....did you follow the set-up instructions, that came with your Hurst? I've installed a few Hurst shifters, over the last 40 years, and will freely state that they have a number of adjustments that A) make them the excellent performers that they are; and B) WILL take a little time to PROPERLY accomplish.
Old Feb 15, 2017 | 08:08 PM
v8srfun's Avatar
v8srfun
Do yourself a favor have someone tap your factory shifter all the way down to the bulge. Then cut it down to size. You will get the best of both worlds that you get buttery smooth shifts but still is a shorter shift.
Old Feb 15, 2017 | 09:32 PM
striper's Avatar
striper
That's good advice, but I did that to a C6 Z06 shifter and it is really nice. It works great and I have no need to look for a new shifter.
Old Feb 15, 2017 | 10:15 PM
v8srfun's Avatar
v8srfun
That is what I wanted to do but I am cheap and broke lol
To hurst shifter
Old Feb 15, 2017 | 10:21 PM
chasboy's Avatar
chasboy
Oldtimer
with my friend. Between what I "took off the top" and from the bottom "bulge " area, my shifter is now at minimum 2" shorter and I love it.
Old Feb 16, 2017 | 09:03 AM
chasboy's Avatar
chasboy
Oldtimer
Only difference between Striper and mine is I stayed with the stock shifter, so....no cost, just some time.
Old Feb 16, 2017 | 12:39 PM
dbgoodwin's Avatar
dbgoodwin
That c5 mgw piece posted by patches is one sexy piece. I love my b&m to death, it's perfect for me, but I really want to drive a car with an MGW to see what the hype is all about.
I did drive rive a car with a hurst and didn't really like it, as well as the shortened c6 shifter. Neither were what I was looking for in a shifter. The Hinson also shows promise because it's super tight (apparently) and pretty notchy.
