hurst shifter
Old Feb 16, 2017 | 02:27 PM
v8srfun's Avatar
v8srfun
Originally Posted by dbgoodwin
That c5 mgw piece posted by patches is one sexy piece. I love my b&m to death, it's perfect for me, but I really want to drive a car with an MGW to see what the hype is all about.
I did drive rive a car with a hurst and didn't really like it, as well as the shortened c6 shifter. Neither were what I was looking for in a shifter. The Hinson also shows promise because it's super tight (apparently) and pretty notchy.
I can appreciate a tight shifter but when it is so tight and notchy that it actually slows your shift down the purpose has been defeated. It is about practicality and purpose. The reason I ditched the hurst was because it was so notchy and tight that you could easily get the incorrect gear when shifting quickly.
Old Feb 17, 2017 | 08:33 AM
james2828's Avatar
james2828
Cruising
Originally Posted by leadfoot4
I have to ask, since you didn't seem to respond to my question.....did you follow the set-up instructions, that came with your Hurst? I've installed a few Hurst shifters, over the last 40 years, and will freely state that they have a number of adjustments that A) make them the excellent performers that they are; and B) WILL take a little time to PROPERLY accomplish.
Had the flu....
Yes I did follow the instructions and adjustments I have worked on it a couple of times and the last ( just recently) did improve the action
Thanks for your help and the time it took
Old Feb 17, 2017 | 12:38 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by james2828
Had the flu....
Hopefully, as the shifter "loosens up" a little, through usage, you'll like it more. Did you adjust the "neutral gate" while you were in there?
Old Feb 17, 2017 | 07:58 PM
dbgoodwin's Avatar
dbgoodwin
yeah, like I said I really didn't like the hurst at all. It was harder to find gears while still feeling sloppier than my b&m. Between stock and hurst I would choose stock.
Old Feb 18, 2017 | 12:49 AM
JETZ's Avatar
JETZ
Hurst. Cut down (2x ), with a modded C6 ****. No issues , luv it.
frank
Old Feb 18, 2017 | 09:46 AM
james2828's Avatar
james2828
Cruising
ya I basically loosed the set screws so they we loose.. feels good .. we'll see
Old Feb 18, 2017 | 02:29 PM
leadfoot4's Avatar
leadfoot4
I think you're missing my point. When the shifter is in neutral, look down where the shift rod (that goes back to the transmission), and see if the hole in the rod lines up with the hole in the clamp. If these two holes don't line up, you have to loosen the clamp and adjust until the two holes do line up (with the shifter remaining in neutral). This adjustment insures your ability to properly select all gear positions.
Old Feb 19, 2017 | 10:03 AM
james2828's Avatar
james2828
Cruising
you are correct I did miss that ...I will soon try this out..
