Help
Old Apr 13, 2017 | 06:05 PM
c5corvette48's Avatar
c5corvette48
Cruising
Default Help
I Have a 1998 corvette and the battery went dead and now with a fresh battery the car wont start ..This happened before to the car about 7 years ago and I had to refresh the computer and it was fine ...during the last 7 years I had a real bad stroke and don't remember what I did ..Can someone please Help Me...THX Bob
Old Apr 13, 2017 | 07:08 PM
JR-01's Avatar
JR-01
Is your "fresh" battery fully charged and do you have clean tight connections?
Old Apr 13, 2017 | 08:24 PM
c5corvette48
Cruising
Yes it is a brand new battery and every thing is tight
Old Apr 13, 2017 | 08:41 PM
JR-01's Avatar
JR-01
Brand new batteries are not always 100% charged. C5s are touchy when it comes to low voltage. The first thing I would do is make sure the battery is fully charged and then work from there. Will the battery crank the engine over? If not, is there any lights or sounds?
Old Apr 13, 2017 | 10:05 PM
c5corvette48
Cruising
It is a new battery and is fully charged and the engine wont crank the last time this happened I had to reflash the computer but since I have a real bad stroke ..I cant remember how to reflash the computer.
Old Apr 13, 2017 | 10:11 PM
c5corvette48
Cruising
I Have a 1998 corvette and the battery went dead and now with a fresh battery the car wont start ..This happened before to the car about 7 years ago and I had to reflash the computer and it was fine ...during the last 7 years I had a real bad stroke and don't remember what I did ..Can someone please Help Me...THX Bob
Help
Old Apr 13, 2017 | 10:16 PM
Tuco's Avatar
Tuco
St. Jude 15 Year Donor
From: Blessed are the cracked. For they are the ones who let in the light.
St. Jude Donor '08 thru '26
Help
Go over to Tech.
Old Apr 14, 2017 | 01:17 AM
calguy's Avatar
calguy
More than likely starter, or ignition switch.
Bob.
Old Apr 14, 2017 | 08:33 AM
c5corvette48
Cruising
I checked the starter & key switch and they are fine... I know it is the computer needs to be reflashed
Old Apr 14, 2017 | 08:45 AM
JR-01's Avatar
JR-01
How do you reflash the computer?
Did you pull the codes?
Old Apr 14, 2017 | 09:02 AM
rrwirsi's Avatar
rrwirsi
If you have a M6 transmission, maybe the clutch switch is the problem.
Old Apr 14, 2017 | 09:45 AM
twokbolt's Avatar
twokbolt
Are there lights, sounds? Do the gauges sweep? Any codes?
Old Apr 14, 2017 | 10:05 AM
bikeriderga's Avatar
bikeriderga
You should not have to reflash the PCM, but if you do, what tool are you using to do this?
You can download a stock bin file for the PCM from GM or other sources. Here is one site that you can download from.
http://oem1stop.com/content/chevrolet
To Help
