Anniversary Edition C5 inheritance
Old May 14, 2017 | 08:00 PM
dbillow's Avatar
dbillow
4th Gear
Default Anniversary Edition C5 inheritance
I am likely to soon inherit a 2003 Anniversary Edition C5 with around 5K miles on it from my Dad, the original owner. It has been rarely driven and mostly garage kept in southern OH with a cover on it. Original tires still on it. I'm wondering if the tires will still be safe to drive on (decay, not wear concerns) and if anyone has suggestions on what I should do to insure it's road worthiness, etc. and my own safety. I plan to use it as a third vehicle for recreational purposes in NC. Thanks!
Old May 14, 2017 | 08:16 PM
JR-01's Avatar
JR-01
The original tires are no good anymore. Ten years is the very most you should try to get on your tires. Get some good non run flat summer tires and you will be very happy. Time to change all the fluids if they haven't been. Sounds like you have a very nice car.
Old May 14, 2017 | 08:19 PM
Corvette#2's Avatar
Corvette#2
Almost 15 years old ? No, the tires aren't safe. I would for sure replace them. I would also change all of the fluids: Oil, coolant, transmission, differential, clutch, brake.
Old May 14, 2017 | 08:20 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
even if your 15 year old run flats aren't dry rotted by now, putting on a nice new set of non run flats will improve your ride and Vette experience.
Highly recommend.
Old May 14, 2017 | 08:22 PM
BIGZ06's Avatar
BIGZ06
Not sure how far South you are, but Corvette Care in Powell (just North of Columbus) does great work.
I had them change all fluids, give the car a once over and throw on a new set of Bridgestones.
FYI
Old May 14, 2017 | 08:24 PM
FX VETTE's Avatar
FX VETTE
congrats an AE is one of my favorites. I would also change all of the fluids and do a lot of preventive maintenance if I was you.
Old May 14, 2017 | 08:32 PM
JR-01's Avatar
JR-01
Did your Dad change the oil once a year or is it the original oil in it? A 5000K mile AE is amazing. A family heirloom. Take care of it and in 30 years you can pass it on to your kids.
Old May 14, 2017 | 08:56 PM
dbillow's Avatar
dbillow
4th Gear
Thanks everyone. Please keep the ideas and suggestions coming. The vehicle is located in Dayton, OH. Anyone know a good place to take it for the maintenance work that won't charge dealer prices? Or is it worth dealer prices for this car? I buy all my tires from Discount Tire and have been very happy. Would also appreciate any suggestions on fun modifications that won't affect the vintage value down the road....
Old May 14, 2017 | 09:25 PM
Corvette#2's Avatar
Corvette#2
Axle back exhaust. Borla and Corsa are popular choices.
Old May 14, 2017 | 09:51 PM
Koufax's Avatar
Koufax
It is worth paying dealer prices for this car. If your dealer knows what he's doing, then use him. If not, find someone who works on Corvettes. Don't cheap out on maintenance ... it's a sturdy car that doesn't ask for much. Give it what it needs.
Old May 14, 2017 | 09:55 PM
that the tires should be replaced due to age. Lots of good choices are available, especially if you decide to drop the runflats and go with non-runflats. Good luck with the car - the 2003 AE is a beautiful ride.
Old May 14, 2017 | 10:35 PM
jrprich's Avatar
jrprich
Welcome to the 03 AE !
If yours has the F55 Magnetic Shocks be sure to check and see if the shipping "shock stuffers" have been removed from all four shocks. You wouldn't believe how many still have the factory "shock stuffers" still in each shock. I bought my 03 AE as the third owner with 24k and they were still installed and still ruining the ride quality.
https://www.corvetteforum.com/forums...ck-blocks.html
Old May 15, 2017 | 09:21 AM
friou's Avatar
friou
Very nice family legacy. As pointed out by other posters, new tires (non run flats), change out all fluids and get her a good going over by a recomended shop. Doing all of that you give you a new/fresh baseline to start from. If you got/get original paperwork/maintenance records with the car, save everything. Good luck and best wishes!
Old May 15, 2017 | 10:44 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Sorry for the circumstances by which it will come to you.
Oil, trans, and diff fluid changes are pretty easy. You can order jacking pucks or make your own. People commonly use hockey pucks and mod them.
Harbor freight carries the Pittsburgh brand Jacks. They have one which os low profile and extends out about 27". Perfect even for my lowered vette. With that you can swap fluids yourself and it is all very quick and easy. Instructions can be searched on the forum.
Salute to your dad.
Old May 16, 2017 | 07:08 AM
Lexybird's Avatar
Lexybird
Salute to your dad.
Yep ...Not any shade tree mechanic is going to be able to work on this car . These are not average cars . Even lifting it up can severely damage the body if they don't use special lifting pucks . Don't trust anybody without corvette experience. You'd be better off learning through research and doing things yourself plus you'll save a lot of money due to the corvette tax
Old May 16, 2017 | 08:12 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
I'll throw this out there. 14 years old, bone stock and a very desirable car. Sometimes that's the way things were meant to be.
That behind said, it's your car...
Old May 16, 2017 | 11:38 PM
grasshopper645's Avatar
grasshopper645
where are the pics at?
I want odo with todays newspaper and a recent drivers license as proof it wasnt photoshopped.
Old May 19, 2017 | 08:56 PM
Joe Scafide's Avatar
Joe Scafide
Default tires
get rid of the good year run craps u will love the ride with none run flats
To Anniversary Edition C5 inheritance
