Dual zone climate control
Old Jul 5, 2017 | 09:02 AM
vet4me's Avatar
vet4me
Default Dual zone climate control
For the first time in 15yrs I decided to try and use the passenger side ac temperature control.I turned the **** and nothing changed.the only way to adjust the temp is by using the driver side control.Is there something else that has to be done first or is the passenger side control not working?
Old Jul 5, 2017 | 09:04 AM
02MillenniumVette's Avatar
02MillenniumVette
Your passenger side is not working. When I had my '02 all I had to do was turn the passenger side and it would change.
Old Jul 5, 2017 | 09:55 AM
peteinpa's Avatar
peteinpa
I have the same in my 2000.
Old Jul 5, 2017 | 10:24 AM
jmohn's Avatar
jmohn
Be aware, the passenger side control only changes the temperature "moderately"; it's not a "full range" control like the driver's side.
Old Jul 5, 2017 | 11:50 AM
MBVette's Avatar
MBVette
St. Jude Donor '05-'06-'07-'08-'09-'10
And the passenger side will not change the temp reading in the display.
Old Jul 5, 2017 | 12:00 PM
Bob_VII's Avatar
Bob_VII
Basically, the passenger side allows you to set temp up to +/- 10 degrees from the driver's side. There is no feedback other than the actual vent air temperature.
Old Jul 5, 2017 | 12:44 PM
Nabcoinc's Avatar
Nabcoinc
Agree👍
Old Jul 5, 2017 | 03:42 PM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
With the ignition on but engine off, when you turn the passenger dial if you listen carefully, you can hear the vents opening/closing.
As others mentioned, passenger **** won't affect the display. That's why there's a white line on the passenger **** and not the driver's ****. It only controls the passenger vents and how much air flows to them is my understanding.
To Dual zone climate control
