Inside rear view mirror
Old Jul 21, 2017 | 05:45 PM
jjc508520's Avatar
jjc508520
Default Inside rear view mirror
Any way to tighten it? I hit bumps and it droops - want it nailed down for upcoming track day....
Old Jul 21, 2017 | 11:02 PM
I looked at my mirror and didn't see any way to tighten. Will be interested in hearing if there is a way.
Old Jul 22, 2017 | 01:18 PM
knewblewkorvette's Avatar
knewblewkorvette
No, I there is no adjustment to tighten.
I had problems with mine going down too in my 98. Wasn't from bumps though, the bass from the stereo did it and so did heavy acceleration (767 rwhp)
I was the only driver so I put a dab of glue in the ball. It works, but you can never adjust mirror again.
Old Jul 22, 2017 | 01:32 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
I need to look at it closer, but is there a way to drill and tap a hole from inside the mirror for a set screw?
Old Jul 22, 2017 | 02:56 PM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
You couldn't try and remove the ball part and bend the prongs out some, without breaking them? I had mine out the other day with a connector problem and just glanced at that part.
To Inside rear view mirror
