[Z06] Engine woes. Suggestions??
Old Jul 22, 2017 | 10:17 AM
motorjunkie's Avatar
motorjunkie
Default Engine woes. Suggestions??
Purchased an 03 model with an obvious lifter noise. Super cheap. Once we replaced the lifters however, we discovered a bottom end knock. At first you can't even hear it. Then once the car gets warmed up it becomes fairly obvious. The car makes mad power with tune, Cam and long tubes. Oil pressure is good the engine is a low mileage crate motor. Heads have been off and bores were super clean etc. our mechanic pulled the heads and replaced the rockers saying that he thought we had a bad rocker that had lost the needle bearings like they are prone to do. He thought this may have happened during the lifter repair. Unfortunately this did not fix our problem. Trying to decide what the next step should be. Any suggestions?
Old Jul 22, 2017 | 10:33 AM
Moto One's Avatar
Moto One
Does the Crate motor have a guarantee?
Mark.
Old Jul 22, 2017 | 04:53 PM
motorjunkie
Mark.
The crate motor was installed several years ago. Prev owner.
Old Jul 22, 2017 | 06:05 PM
Spaceme1117's Avatar
Spaceme1117
If it is indeed a rod knock, your only options are new motor or rebuild the current one.
Old Jul 23, 2017 | 07:38 AM
motorjunkie
Ummm yes. I figured that. I guess I was looking for some performance upgrade advice. Stroker short block. Engine swap options etc....
Old Jul 23, 2017 | 02:57 PM
Spaceme1117
Sorry, Captain Obvious here. If it were me and I had the cash, I would put an LS3 crate motor in and call it a day.
To Engine woes. Suggestions??
