Torque Arm?
Old Aug 10, 2017 | 11:55 AM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default Torque Arm?
Anybody have a picture of the torque arm on a C5? I need to double check and tighten if needed the bolts. Want to know what I need to be looking for.
thanks
Old Aug 10, 2017 | 01:24 PM
StingrayRebel's Avatar
StingrayRebel
this isn't an fbody
Old Aug 10, 2017 | 01:31 PM
XtremeVette
Yeah..never mind...just noticed it was in the C4 section. lmao! My BAD!
Iam getting a clunking noise when accelerating and decelerating. Sounds like possibly a U joint...not sure what though but I do know there are quite a few things that can cause this symptom. Any tips I things I can check before just replacing items?
Old Aug 10, 2017 | 02:11 PM
JR-01's Avatar
JR-01
Originally Posted by 8VETTE7
What's a "torque arm"?
I am glad you asked that first. He had me stumped.
Old Aug 10, 2017 | 04:58 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Without doing a lot of eye and ears on the car on the rack, here is some LEARNING and THOUGHTS
The C5 and or C6 does NOT have U joints. We have a Torque Tube (TT) and inside the TT the propeller shaft has vibration / flex joints called rubber couplers.
They deteriorate and crack and fail over time and make that noise.
TT and the guts:
RUBBER COUPLER:
SOMETHING ELSE TO LOOK AT:
Remove the rear wheel and look in the center of the wheel hub. There is a very large NUT that secures the rear CV output shaft to the rear wheel HUB. See if that nut is LOOSE.
Bill
Old Aug 14, 2017 | 03:47 PM
XtremeVette
Thanks Bill! I will be sure to check. My plans are to jack the car up and then have the girlfriend go through the gears and then apply gas and then left off quickly to reproduce the problem and see if I can hear and watch for where I hear the clunking coming from. Iam leaning toward the torque tube couplers (which I did know about but prayed it wouldn't be that). The clunk to me when driving sounds like its coming from the middle of the car. But I will know more when I get under it. Thanks again guys!
PS: I will check that axle nut too!
To Torque Arm?
