Front lower spoiler
Old Oct 24, 2017 | 03:56 AM
bdiddo's Avatar
bdiddo
Default Front lower spoiler
Quick question- my '01 coupe is lowered and I was considering cutting my front spoilers an inch or so to have a bit more clearance. Will this cause any cooling issues? I have a DeWitt radiator don't even come close to ever over heating even in Phx,AZ
thx
Old Oct 24, 2017 | 08:10 AM
CactusCat's Avatar
CactusCat
You'll probably be fine. If it starts overheating, just put a new air dam back on. Easy peasy.
Old Oct 24, 2017 | 08:31 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Old Oct 24, 2017 | 08:52 AM
StingrayRebel's Avatar
StingrayRebel
you should be fine, I have done the same to mine and haven't had any problems
Old Oct 24, 2017 | 11:34 AM
with the others. You should be OK.
Old Oct 24, 2017 | 12:09 PM
El original's Avatar
El original
Total removal of mine...years ago. Did not notice any difference in engine temps. Looks better IMHO also.
Old Oct 24, 2017 | 12:39 PM
Chicago1's Avatar
Chicago1
Alot of people says it's needed for airflow or you will overheat. I have had mine off for years and no issues. I recently put it back on just to see if it made a difference...It made 0 difference..
Old Oct 24, 2017 | 12:49 PM
imgn tht's Avatar
imgn tht
St. Jude Donor '13, '15
Have run mine like this for over a year, no issues.
Old Oct 24, 2017 | 01:34 PM
bdiddo's Avatar
bdiddo
Default Front Spoiler removal
Thank you for the replies!
Old Oct 24, 2017 | 02:31 PM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
The Center section is the only spoiler needed for cooling.
Old Oct 24, 2017 | 04:47 PM
bc6152's Avatar
bc6152
Correct me if I'm wrong but I think that there are three sections of spoiler attached to the underside front of the C5. Did you remove all three sections and no issues? I'd like to do the same.
TIA
Old Oct 24, 2017 | 06:19 PM
Chicago1's Avatar
Chicago1
TIA
mine are all removed...then I put the middle one back..No difference
Old Oct 24, 2017 | 10:42 PM
ChrisLSx's Avatar
ChrisLSx
Don't they also serve to keep air out from under the car (thus help with both stability at speed and drag)?
I'd be curious to see your results as I'm in Phoenix as well and with my 180 T-stat (and adjusted fans), my coolant is almost never over 205 degrees max (usually cruse at 195).
Old Oct 25, 2017 | 10:16 AM
6speedsteve's Avatar
6speedsteve
Sides removed, when I first cut the center section even with my fangs I was always running on the 220 degree mark at slow speeds 30-40, I then cut a new one to hang 1" below the fangs & temp is 190-205 mark at those speeds, unless I drive aggressively it stays below the 220 mark.
Old Oct 25, 2017 | 12:00 PM
ChrisLSx's Avatar
ChrisLSx
Don't do it. See post #10 in attached thread:
https://www.corvetteforum.com/forums...t-air-dam.html
Old Oct 26, 2017 | 02:18 AM
bdiddo's Avatar
bdiddo
ok. I checked out the post camaroguy recommended. I believe that to be correct but I am looking to only remove just over an inch (not the whole assembly).
what is really interesting is that i am looking to install a magnusen supercharger this winter. the installation instructions state to cut the top portion on the line. I would imagine they wouldn't suggest doing so if it was going to materially detrimental to performance
Old Oct 26, 2017 | 09:41 AM
ChrisLSx's Avatar
ChrisLSx
I believe people in the thread I posted even said trimming is one thing (particularly on lowered vehicles), removing it in its entirety is a whole different situation. Trimming (on a lowered vehicle) shouldn't change anything, particularly if you don't take off more than the vehicle has been lowered.
I read somewhere that even splitters on race vehicles have an optimum height and it's at least 1" (or 2"... I can't remember) off the ground. Lower than that, the splitter actually looses effectiveness and drag goes up exponentially.
To Front lower spoiler
