Head unit options for C5
Old Oct 27, 2017 | 11:38 AM
cvitullo's Avatar
cvitullo
Default Head unit options for C5
looking for some advice from the experts here that have been there done that. I recently bought a 98 coupe, Bose audio, single CD, and I want either a bluetooth or apple / usb head unit. I've check Crutchfield and I see some nice units but I'm afraid I'll lose that Bose sound, and advice for a decent head unit?
Old Oct 27, 2017 | 12:28 PM
Tsumi's Avatar
Tsumi
Get the Axxess XSVI-2004 and you will be able to keep the stock Bose system.
Old Oct 27, 2017 | 12:53 PM
02BlownZ06's Avatar
02BlownZ06
You like how the Bose sound??
Old Oct 27, 2017 | 12:59 PM
Tsumi's Avatar
Tsumi
After replacing the rear speakers and the tweeters, I thought it sounded good.
Old Oct 27, 2017 | 01:24 PM
cvitullo's Avatar
cvitullo
well, I've not had the chance to hear it yet
Old Oct 27, 2017 | 01:25 PM
cvitullo's Avatar
cvitullo
thanks Tsumi, I'll check it out, Tsumi, same Tsumi as the one on Harley Tech Talk?
Pete
Old Oct 27, 2017 | 01:27 PM
Tsumi's Avatar
Tsumi
Nope, not on Harley Tech Talk.
Old Oct 27, 2017 | 01:28 PM
Crosis's Avatar
Crosis
Losing the Bose sound is a bad thing?
Old Oct 27, 2017 | 01:32 PM
cvitullo's Avatar
cvitullo
Ok - thanks for the tip on the adapter
cvitullo's Avatar
cvitullo
hum, I don't know, I guess I'll find out soon
Old Oct 27, 2017 | 01:34 PM
UM Rebel's Avatar
UM Rebel
I got the PAC REOM-1 VET-1 and a cheap radio off the auction site. Connected plug and play to Bose amp and spekears. Sounds great. Radio has FM, Bluetooth, AUX, USB and SD card inputs. Total cost of every thing was about $60.
Old Oct 27, 2017 | 01:42 PM
cvitullo's Avatar
cvitullo
Nice
Old Oct 27, 2017 | 06:55 PM
Corvette#2's Avatar
Corvette#2
My factory Bose head unit died. So I bought a single DIN Alpine CD player with usb and bluetooth and used a PAC adaptor to interface with the stock Bose drivers. Surprisingly, it made a noticeable improvement in sound quality. Less distortion, tighter bass, overall a lot cleaner sounding at higher volumes. Of course, replacing the factory Bose drivers would have been even better, but I didn't want to put a ton of money into my car's stereo.
Old Oct 27, 2017 | 07:54 PM
GCG's Avatar
GCG
As mentioned above, to properly replace just the head unit leaving the rest of the system in place you will need an adapter (not just a harness) to provide the required interface. This is due to the way the factory system was designed.
The 2 most common adapters are:
Replacing the head unit should be just plug-and-play by using either one. Both have setup adjustments to customize sound/levels. After tweaking them to your liking, they shouldn't require any further touching.
A double DIN is very nice, but if budget doesn't allow it and you want to consider a single DIN, then you would need an adapter plate to secure the new unit in place and provide a nice finish.
Here is an adapter plate that matches the interior very well. It has the word "Corvette" engraved in it that can be set up with backlighting (or you can customize the lettering).
From their website:
CNC machined aluminum faceplate, finished in either a fine black texture finish or brushed aluminum.
The lettering can be above or below the head unit opening, there is also a non illuminated version with the head unit located in the center of the mount.
The main lettering illumination available in red, blue, green, yellow, white LED’s and also red mini lamp illumination.
Custom lettering and design is available.
Old Oct 27, 2017 | 07:58 PM
GCG's Avatar
GCG
If you want to take this a little further, without a doubt, the easiest and least expensive way to upgrade the system with the more bang for your buck is new speakers that can be bolted on in place of the factory ones, keeping the rest of the system intact.
OEM C5 Speaker Sizes:
-Front
Twiddler: 3.5"
Subwoofer: 8"
-Rear Twiddler
Coupe: 6.5"
FRC/Z06/Convertible: 5.25"
Get 3.5" 2-way coaxial speakers to replace the doors' twiddlers and 2-way coaxials of the right size for the rear. Don't touch the OEM subwoofers.
You will need to further verify fitment, but a quick search produced this:
JL Audio Evolution™ C2 Series 2-way car speakers:
  • C2-350X (3-1/2")
  • C2-525X (5-1/4")
  • C2-650X (6-1/2")
Not only they are from the same manufacturer, but they all belong to the same line. This should reasonably assure you they have the same timbre.
You are going to need
<b>this kit</b> this kit
as well. One kit will do both rears.
Old Oct 27, 2017 | 08:04 PM
Tsumi's Avatar
Tsumi
I went with Kenwood 3.5s and 6.5s. I noticed some improvement with a Kenwood single din head unit, but not much. I recently replaced the Kenwood single din with a Joying single din with screen (one of the new Intel ones), and there was a much more noticeable difference in sound quality. Sound was a lot clearer. If you don't need or want too much bass, keeping the stock Bose system and upgrading the speakers is the way to go. The rear speakers are powered by the head unit, so it shouldn't be too difficult to splice in an amp if you wanted to; of course, you would be limited by the stock wiring.
Old Oct 27, 2017 | 10:03 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Do it right the first time and go double din for the head unit.
They're much more flexible with modern options you won't find on a single din.
To Head unit options for C5
Old Oct 28, 2017 | 04:49 PM
Dirty Dog's Avatar
Dirty Dog
If you're happy with the factory head unit, just keep it. I got an adapter from Double D Mods that plugs into the AUX jack on the back of the factory head unit and allows me to charge and play my iPhone through the factory system.
Old Oct 30, 2017 | 04:14 AM
jumpmanmb87's Avatar
jumpmanmb87
What double din piece is this? Do you use the adapter if you change the speakers?
Old Oct 30, 2017 | 04:49 AM
awches's Avatar
awches
In talking with Crutchfie;d a few weeks ago and telling them all I wanted was a Pioneer unit as I had installed in my truck several years back. And, wanted to keep the stock speakers, didn't want/need bluetooth stuff. They set me up with an order list with single din nearest to what's in my truck and adapters for a little over 200 bucks. I'll probably order it next month and fix the display problem on my temp control all at the same get go. Plus pull the Sirius set up and sell it and put my ash tray set up back in with usb charge ports .
