Battery cable bolt replacement
Old Jan 9, 2018 | 03:31 PM
Dark Sarcasm's Avatar
Dark Sarcasm
Default Battery cable bolt replacement
My positive battery cable bolt is all boogered up. Is it possible to replace just the bolt? I messed with it for a while with a wrench and some pliers but I didn't want to screw it up. Figured I would ask here first before I'm buying an new cable or something.
Old Jan 9, 2018 | 03:45 PM
Dark Sarcasm
https://www.corvetteforum.com/forums...able-bolt.html
I found this but it doesn't look promising. I'm gonna try it anyway. I guess if all else fails I can just get another battery cable - PITA
Old Jan 9, 2018 | 06:37 PM
glbeauchamp's Avatar
glbeauchamp
Replacement battery bolts are available at I would venture to guess any auto store. Like the link says, warm up the plastic cover. Stretch the plastic cover over the bolt. The bolt will come right out of the terminal end as the only thing holding it to the terminal is the cover itself. Slip a new bolt in the hole and slip the cover back over the top of it. Reinsert into battery, being careful not cross thread it (which is why I had to replace mine in the first place). The head of the terminal is 5/16". If the bolt is corroded you may have to slip the cover off the bolt while the terminal is still connected to the battery and use a visegrip or something to unscrew it. Best of luck...
Old Jan 9, 2018 | 07:04 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
This is where I bought my bolt a few years back. Looks like the price has dropped in half.
https://www.ebay.com/itm/GENUINE-GM-...item258595e8f2
Old Jan 9, 2018 | 07:14 PM
Black 03 Z06's Avatar
Black 03 Z06
Good to know after many years of taking the battery out the head of the bolt is getting funky on mine as well.
Old Jan 9, 2018 | 08:26 PM
digitaloutsider's Avatar
digitaloutsider
Any auto parts store sells them.
Old Jan 9, 2018 | 09:30 PM
Dark Sarcasm
Thanks guys, I've got the bolts already. I bought them to install into the battery to have a place to hook up the battery tender over the winter. Battery is disconnected while I re-wire the amps, subs, install a new box, install a sub control.
Hopefully I can heat up the plastic and get the old one out with out any isuues.
Old Jan 9, 2018 | 10:22 PM
glbeauchamp
When I changed my bolt I didn't heat up the cover. It was pretty stiff but came off fairly easily. Warming it up would definitely make it easier to remove I' m sure.
Old Jan 9, 2018 | 11:58 PM
You should be able to get the bolt out using the procedure above. No need to buy a new cable.
To Battery cable bolt replacement
