Hyperflash harness
Old Feb 8, 2018 | 09:40 PM
Lee Caudel's Avatar
Lee Caudel
Default Hyperflash harness
I have new LED turn signal /brake lights. I also have a new HYPERFLASH Harness. Where is locaction to plug the harness in? Should you still use Inline resistors ?
Old Feb 8, 2018 | 09:59 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
The hype flash harness replaces the inline resisters. The harness plugs into the connector concealed behind the knee bolster on the drivers side.
Old Feb 8, 2018 | 10:03 PM
Ed Ramberger's Avatar
Ed Ramberger
Remove the panel under the driver dash - 4 screws. You will see the connector right by where it meets the center console - look for a connection that matches the hyperflash harness. About 15 minutes to install.
Old Feb 9, 2018 | 09:42 AM
FX VETTE's Avatar
FX VETTE
Old Feb 9, 2018 | 11:06 AM
6speedsteve's Avatar
6speedsteve
Here is a thread.
https://www.corvetteforum.com/forums...per-flash.html
Only video I could find.
Old Feb 9, 2018 | 12:20 PM
You should not have to use inline resistors when you install the hyper flash harness. I did not use them when I installed the harness on my car and everything works as it should.
Just be careful when removing/re-installing the knee bolster as it slips under the center console bezel by the ignition cylinder. I would advise you to loosen the bezel to safely get the knee bolster out and then back in. You don’t have to do this, but I feel it is better than cracking the radio bezel when you try to get the bolster out from under it.
Old Feb 9, 2018 | 03:40 PM
twill's Avatar
twill
Default No resistors needed.
I originally had the resistors but still had problems. I then removed them and installed the hyperflash harness and have had no problems since.
To Hyperflash harness
