[Z06] Heads/Cam combo advice
Old Feb 10, 2018 | 12:20 PM
Not4spd's Avatar
Not4spd
Default Heads/Cam combo advice
Looking at finally doing a heads/cam combo for my Z. Just not sure where to start or what to look for.
Some background on the car:
2003 Z06
Mods: Shorty headers/X-pipe/Corsa Extreme/Air Intake
My Z is just a weekend toy and made 370whp about 4 months ago.
I would like to make 440-450whp NA and 550-600 on spray. I imagine to obtain the goal more easily I will need to switch over to longtubes. I have no issue as long as the car could remain emissions compliant.
Would I be better off just doing some ported LS6 heads? Any cam suggestions or what to start reading up on to help obtain my goal?
Old Feb 10, 2018 | 01:28 PM
99blkfrc99's Avatar
99blkfrc99
you lost me at emissions compliant. Get a procharger and pulley down for 600.
Old Feb 11, 2018 | 01:41 PM
mykream's Avatar
mykream
BTR Stage 3 cam... Have the heads ported and you could shave some off the deck.
This should get you right around 430-440 probably. But yes, definitely put longtubes on it.
Old Feb 11, 2018 | 02:04 PM
Smoken1's Avatar
Smoken1
Only problem with that is he has emissions tests, so he can't use LT's
Old Feb 11, 2018 | 02:05 PM
mykream's Avatar
mykream
He most certainly can..
Old Feb 11, 2018 | 11:18 PM
ZFLASH's Avatar
ZFLASH
St. Jude Donor '10-'11-'12-'13-'14, '16
I've had LT headers on mine for 15yrs in Texas and never had a problem passing, as long as he has cats it shouldn't be a problem or know a friendly inspection shop. You have some nice shops up there in D/FTW area, just post in the SW section. Good luck, L8R ZFLASH
To Heads/Cam combo advice
