Shopping tips
Old Mar 5, 2018 | 10:17 AM
ff_whiz's Avatar
ff_whiz
2nd Gear
Default Shopping tips
I have found a 2003 50th anniversary edition with 85k miles. Great price, clean carfax, all that needs to be done is to physically go look and drive. With this being my first corvette buying experience, is there anything outside of the normal inspection process i need to look at?
Old Mar 5, 2018 | 11:54 AM
glbeauchamp's Avatar
glbeauchamp
Sticky #3 at top of C5 general . Here it is: https://www.corvetteforum.com/forums...ion-files.html
And #5: https://www.corvetteforum.com/forums...must-read.html
Old Mar 5, 2018 | 04:10 PM
Also look at the sticky on weights, measurements, etc in the C5 Tech section.
Old Mar 5, 2018 | 07:01 PM
FX VETTE's Avatar
FX VETTE
Look underneath at the F55 shocks and make sure they aren’t leaking. Check for the yellow “shock stuffer” strip while you are under there. I would take a look at the diff too.
Old Mar 5, 2018 | 07:54 PM
Underachieved's Avatar
Underachieved
What is the shock stuffer?
Old Mar 5, 2018 | 08:10 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
When the cars were shipped there was a yellow block stuffed in to control the movement during transit. The dealer was "supposed" to remove these prior to delivery.
It's amazing how many post about a horrible ride only to find the shock stuffers still in place after all these years!!
Old Mar 5, 2018 | 08:16 PM
FX VETTE's Avatar
FX VETTE
https://www.corvetteforum.com/forums...-stuffers.html
Old Mar 5, 2018 | 08:29 PM
m4bgringo's Avatar
m4bgringo
Pull all the codes out of there and make sure you have internet access so you can look them up and see if there are any real troubles........
Old Mar 5, 2018 | 08:39 PM
ALLEGRO's Avatar
ALLEGRO
Just to compile what the others are saying, is do your research on things that are unique to the '03 AE and then get as much history as you can about this car. If it is in a condition of "well kept" then you are probably on to a good thing. Definitely pull the codes for both current and historic problems.
One thing for me is it a "one owner" car? What you are looking for is a car that has been LOVED and just in need of another HOME.
Good luck
To Shopping tips
