Starter part number
Old Apr 12, 2018 | 12:03 PM
Gordon2468's Avatar
Gordon2468
5th Gear
Default Starter part number
I own a 2000 Corvette
i think with an aluminum block!!!
i hear that there is a starter problem coming loose a breaking the flange of the block!!
does anyone know of this problem!!!
thanks, gordon2468
Old Apr 12, 2018 | 12:24 PM
Smoken1's Avatar
Smoken1
Here ya go.. Read thru this thread
https://www.corvetteforum.com/forums...the-block.html
Old Apr 12, 2018 | 01:17 PM
Dark Sarcasm's Avatar
Dark Sarcasm
It's hard to read through the old threads with references to blocked pictures. From what I gather the newer style starters that replace the short bolt with a built in bracket and long bolt prevents the block from cracking.
Old Apr 12, 2018 | 03:52 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
thanks, gordon2468
All 1997 and newer Corvettes have aluminum blocks.
I bought a new starter off Amazon for around $90 shipped.
Old Apr 12, 2018 | 05:52 PM
Dark Sarcasm
Bosch BSH SR8581N part number for the unit I bought. It comes with the long bolt.
I replaced mine yesterday but didn't research it first. Just figured it was a starter that needed replacing and wouldn't have any drama around it, I forgot it's a C5 I'm dealing with. Lol
Old Apr 12, 2018 | 11:49 PM
StingrayRebel's Avatar
StingrayRebel
I also recommend the bosch starter... I wrapped the body, solenoid, and wiring with heat barrier to hopefully help with longevity... if you have headers and/or race the car it gets very hot down in the starter area
Old Apr 13, 2018 | 09:43 PM
Gordon2468's Avatar
Gordon2468
5th Gear
  1. thanks for the information
Old Apr 13, 2018 | 10:00 PM
foggy's Avatar
foggy
I used the Bosch starter when I replaced mine last fall.. Mine was fine, but
I was doing headers.. So I did it as a maintenance procedure. It made me feel better
that would NOT have this issue.. I also did new rocker arms and springs so that would
never be an issue
Old Apr 13, 2018 | 10:06 PM
Gordon2468's Avatar
Gordon2468
5th Gear
What is the Rocker issue
thank you
Old Apr 13, 2018 | 10:31 PM
foggy's Avatar
foggy
The needle bearings can "fall out".. They are just pressed in with a retainer like thing..
You can upgrade by rebuilding your original with new shafts that have "captured" ends
that retain the bearings mechanically or opt for aftermarket rockers.
Usually just a problem on higher mileage, raced cars, or anytime cam has been upgraded.
The spring issue is mostly with the 02-04 Z06's ..
Do any kind of search on the rockers and you'll see exactly what i'm referring to
Old Apr 13, 2018 | 10:34 PM
Gordon2468's Avatar
Gordon2468
5th Gear
Thank you so much for the information I appreciate it
To Starter part number
