chain and gears
Old Apr 15, 2018 | 04:38 PM
Mitch45's Avatar
Mitch45
Default chain and gears
Thinking about when I do the balancer if I should do the chain and gears . I read where they are suppose to be good to 200,000 miles . Anyone else consider doing this ?
Without a distributor it is a little harder to check the chain slop.
Old Apr 15, 2018 | 05:24 PM
zachaeous's Avatar
zachaeous
I pulled and rebuilt the motor in my 2001. It was well maintained and was removed for a oil leak. It had 144,000 miles on it. I replaced the original chain and gears. The gears showed no visible wear and the original chain had about the same amount of slack as the new replacement.
I would not replace it if I was just doing the balancer if it was mine.
Old Apr 15, 2018 | 06:03 PM
Ricks99FRC's Avatar
Ricks99FRC
When I replaced the balancer I also installed a ls2 timing chain and a Chevrolet high volume oil pump for peace of mind at about 220,000 miles.
Old Apr 15, 2018 | 10:59 PM
To chain and gears
