I'm not frustrated, yet. I've only had my Vetter for a month, but I plan on keeping this car along time so I plan on purchasing certain equipment considering it an investment i.e. low profile floor jack. Granted I'm only a shade-tree mechanic - not like many of the masters that contribute on this Forum - but I've learned what I can do and what I can't. I don't mind paying a bit for what I can't do. As far as getting the lug nuts off, get a longer handle - leverage. Stay away from frustration, pursue the fun
A good harbor freight jack that can get the car up is ~$50-$60. Set of four decent jack stands will run you ~$30-$40. A four way tire iron (I actually recommend having a proper torque wrench even for lugs as lugs are supposed to be torqued, but "tight" will work) can be had most everywhere for ~$15. Can make jacking pucks for $15 with locally sourced stuff (look online for guides).
Jack car up in rear with new jack, put rear on stands, get at the front with your freshly made pucks, put on stands, get the wheels off, clean calipers, loosen them off, mask off everything not to be painted (including car obviously) paint caliper faces and bodies, while calipers off remove rotors (don't have to mask your rotors since the first few times you apply the brakes it'll knock the paint off the braking surfaces), paint, let dry, install rotors, install calipers, install wheels, lower car, let all sit overnight.
Is it just me or are there any other owners frustrated that they can’t perform some of the work on their vettes due to lack of tools and mechanics????? I want new wheels but want to paint brake calipers and rotor hubs first. Makes sense right....except I can’t take the wheels off the car cuz I don’t have a jack and not sure I have the strength to get lug nuts off either! Just WTFFFFFFFFFFFFF
Your statement really doesn't make sense. The tools you need to do that job are the same tools you would need to do those things on any car. They're basic tools that should be found in anyone's garage.
Can do all of that competently in an afternoon.
Used hockey pucks sell around here for $1 each. 3/4" (ID) eye screws are about 50 cents. In my opinion, the lug nuts should be torqued (100 lbs, according to Chev), then retorqued after 50 or so miles. Here's a link for a torque wrench": https://www.harborfreight.com/catalo...+torque+wrench. You can get a jack there, too. Once you start working on your Vette and everything turns out alright, you will probably want to do more. If it doesn't, well.....
So buy the tools and get over it. If strength is a problem with the lug nuts buy an impact tool or put a pipe on the end of your breaker bar for leverage. As far a needing painted calipers …….. your car will continue to function if you forget this idea. Mine is 16 years only without that "bling" feature.
Learning to remove tire should be a basic for every driver. I was taught to change a tire by my dad and I was required to do so before I was allowed to drive. Having the strength to remove the lung nuts, could be a problem, however there are easy solutions, such as an extension bar. I'm sure there are other Vette owners in your areas that would be very happy to help you learn the processes. Learning to change a wheel/ tire is a great place to get started 'turning a wrench'. Next is an oil change,,,,,,,,
i’ve had mine for about a month now myself. Determined to learn the mechanics
of the car! Love this forum. Tons of good solid advice and um yeah... lots of opinions!😎
If you're planning on doing any work on any car, tools are an investment. Also, if you are not confident in your abilities, don't put you or others at risk. Last thing you want is a wheel falling off going down the road.
Well, he is actually frustrated because he does not have a jack. I suppose he thought the car would lift itself for him. Probably not a guy who should be working on cars. LOL
If you don't have the strength to take lug nuts off, maybe someone overtightened them. Get a breaker bar, with a piece of pipe to extend it if you have to. Then torque them properly.
This is no different than any car. You'll need tools to work on a car, or build a doghouse, or...
I got my first (small) tool set before I got my first car.
If you are going to have to pay someone to carry out every maintenance and repair task on what is at best a 14 year old car (and a 21 year old car at worst), you are going to go broke very quickly. Best to buy new and get the extended warranty.
Not not frustrated. I have a 2000 and I did 4 things when I bought here in 2003. (1). Ensures I had the basic tools to do “basic” work. (2) Ide tidies a good mechanic so I wasn’t dependent on the Stealership when out of warranty. (3). Read and became knowledgeable about the C5 and (4). Joined the Forum, which I have been tapping into members knowledge and experience for 15 years. The Corvette, and especially the C5 is a special car and fun to work on. Sure there are issues but the benefits far outweigh the issues I’ve dealt with. Take a deep breath and enjoy the ride! Don’t forget to wave!
Thanks! Determined to learn. Looking into the HF low profile jack.
Time to invest in necessities! Wish they taught me mechanics
back when I was in school😌
