ECBM decision
Old Nov 15, 2018 | 12:52 AM
dbgoodwin's Avatar
dbgoodwin
I don’t think the battery situation can be stressed nearly enough. If I don’t drive my car often enough I get that occasionally. If I drive it 3-4 times a week at least 15-20 miles, then I never get the warning. This is with a known good optima yellow top.
Old Nov 15, 2018 | 11:23 AM
RtStuf's Avatar
RtStuf
Originally Posted by Jerstoy
I used ABS Fixer several years ago repaired and not had a problem since. Check this website out.
https://www.absfixer.com/how_do_i_remove.php
ABS Fixer
Nixa, MO.
877-648-7530
The OP's Vette is 2000. ABS Fixer is for 2001-2004.
Old Nov 15, 2018 | 01:13 PM
chasboy's Avatar
chasboy
Oldtimer
That was my impression. I would make sure which generation EBCM you have, <just> in case there's an overlap or other anomaly.
I say that because I repaired the one on my C5Z and knew nothing about it other than to remove the module and look for the compromised solder joints. There were 5. I touched them with an iron and the codes left immediately.
The VERY biggest pain is getting the thing out. It's very hard to see and for me tough to distinguish between the mounting bolts and the actual unit's bolts. Ended up with lots of cuts and scrapes but well worth the equivalent.
Old Nov 15, 2018 | 02:29 PM
flyingmfrc's Avatar
flyingmfrc
2020 C5 of the Year Winner- Unmodified
I want to thank everybody for the suggestions and help. I really do appreciate it.
OK, here's the latest.
Since battery was mentioned a couple times I went ahead and did a full charge on it. I drive the car several times a week and it always starts right off and there are no indications of a problem with the battery. I don't think that was the issue.
I checked to be sure all the wheel sensors were firmly attached as well.
I started it again. Got the usual messages, service traction system, service ABS and service handling system and the skidding car icon was lit. So I went into the DIC and found the code 28-TCS-1243H. There were no other codes.
Without clearing the code, I started it again..... no messages and no icon light!!!!
I have no idea what all this means, and who knows if it will show up again, but I'm glad right now.
I did look up the code meaning, and it says BPMV motor pump stalled. I'm guessing that is an ABS pump and probably nothing can be done about it.
I'm still open to hearing any more info regarding this situation, since I can't be the only one this has happened to.
Lost in C5 land, signing off.
Old Nov 15, 2018 | 04:54 PM
dbgoodwin's Avatar
dbgoodwin
You could probably benefit from manually exercising the pump, or by just forcing the car abs to work by locking up the brakes on a wet surface. I’ve seen several write ups on how to manually exercise the pump and several people reporting good results
Old Nov 15, 2018 | 06:00 PM
99mike's Avatar
99mike
St. Jude Donor '17-'18
Your ABS has stalled and like dbgoodwin said, you need to exercise your motor periodically. This happened to me and now I exercise it using my Tech II every 3 months. You can do it other ways at your own risk. This fixed my problem over 5 years ago and haven't had an issue since. Good luck.
https://www.corvetteforum.com/forums...s-weekend.html
Mike
Old Nov 16, 2018 | 12:53 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
See! I wasn't cuckoo....
Old Nov 16, 2018 | 03:28 PM
flyingmfrc's Avatar
flyingmfrc
Well, I just went out and "exercised" my ABS by slamming on the brakes at about 60mph several times. A few chirps from the tires, but stopped pretty quick. Seems like an ABS response. It didn't lock up all fours or swap ends......no more messages either. I'm good for now....
Old Nov 16, 2018 | 04:01 PM
'Shifter's Avatar
'Shifter
NCM Member '09
Great news brother!
Old Nov 16, 2018 | 05:23 PM
flyingmfrc's Avatar
flyingmfrc
Thanks Shifter....what color is your 2000 FRC?
Old Nov 16, 2018 | 05:25 PM
'Shifter's Avatar
'Shifter
NCM Member '09
The bestest color of all....Arctic White.
Old Nov 16, 2018 | 07:06 PM
flyingmfrc's Avatar
flyingmfrc
I checked out your photos. The black wheels look great with the Arctic White. Nice FRC!!!
Old Nov 16, 2018 | 11:52 PM
  #33
Arvalo's Avatar
Arvalo
All of this is making me wish my 99 FRC didn’t have the EBCM code of death : (.
Old Nov 17, 2018 | 12:30 AM
  #34
chasboy's Avatar
chasboy
Oldtimer
FWIW, I know lots of people with pre-2000 cars who’ve had not issues.
Old Nov 19, 2018 | 11:58 AM
  #35
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
I've had the lights come on a few times on my 2000 with 21K miles. I clear the codes, and make sure I "exercise" the traction control and ABS pretty much each time I drive it. I do a couple of hard 1-2 shifts for fun chirping the tires kicking it in, but I also usually dump the clutch a few times on my garage or pole barn smooth slick concrete floor so everything kicks in. I've read on here that wet grass works well too.
Old Nov 19, 2018 | 12:15 PM
  #36
'Shifter's Avatar
'Shifter
NCM Member '09
Thanks man, I'm not really a black wheel guy, (they are actually gunmetal), but they bring the C6z yellow calipers life!
