Scan Tool
Old Dec 13, 2018 | 08:52 AM
Tevroc98's Avatar
Tevroc98
Default Scan Tool
I'm building a restomod with a 2001 Z06 engine. I want to buy a scan tool to monitor the engine when I start it up. Its just the engine and trans in the chassis.No body. I'd don't want to spend a lot of money (under $100.00) for the scan tool. Anyone have one they've bought and found it very useful.Thanks
Old Dec 13, 2018 | 09:13 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
For less than $100 you're not going to get more than a "code reader" !!...what on the engine do you want to monitor ??...for about $350-400 you can get a "Chinese Clone" Tech 2 GM Factory scan tool...best bet for the money !!
Old Dec 13, 2018 | 10:09 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
spent a bit for a HP tuner, but it's amazing what you can do with it !!!!!!!!
Old Dec 13, 2018 | 10:13 AM
Tevroc98's Avatar
Tevroc98
Pounder what were you able to do? Which did you buy?
Old Dec 13, 2018 | 12:11 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
well of course you can tune the car (I'm not there yet) I can disable the skip shift,change fan temps and when they come on,disabled the air pump system, raised the fuel shut off so if the LMC5 fails the car will still run, scan everything engine, trans etc. it's endless !!!!! Bought mine from Summit 499.00 !!!!! (8 credits)
Old Dec 13, 2018 | 12:20 PM
Gordy M's Avatar
Gordy M
If you are going to invest in a scan tool, look for one that has the "enhanced GM codes" as well as the standard SAE codes to read. You can also get one that will load on your PC, for a few dollars more, that can have bi-directional ability. That will allow you to change wheel size, bleed the ABS unit at the wheels, eliminate skip shift and a few other items. You are still under $200 for this ability.
Old Dec 13, 2018 | 12:24 PM
aaronc7's Avatar
aaronc7
What do you want to monitor? A decent cheap option is a bluetooth OBD2 dongle and phone app, but you will pretty much be limited to basic parameters like IAT, Coolant, RPM, MAP, speed, fuel trims, o2 voltage maybe.
Otherwise hptuners is probably your best bet: https://www.hptuners.com/mpvi2/
Old Dec 13, 2018 | 12:25 PM
aaronc7's Avatar
aaronc7
You have a link? I didnt realize there was something that could do all that for under 200
Old Dec 13, 2018 | 05:01 PM
gimp's Avatar
gimp
Knock-off Tech2 is about $250, there's a huge thread on it.
Old Dec 13, 2018 | 08:50 PM
Irish31's Avatar
Irish31
Blue Driver is a good OBD II reader and scan tool that runs off your phone once plugged into the car. $100 on Amazon.
Old Dec 14, 2018 | 08:49 AM
Tevroc98's Avatar
Tevroc98
I’m basically want a scan that can tell me oil pressure,water temp. Nothing fancy. I appreciate any info.
Old Dec 14, 2018 | 10:10 AM
dbgoodwin's Avatar
dbgoodwin
Is there a particular reason you don’t want to run gauges? A lot of people tear out the cluster from trailblazers when doing LS swaps. Here’s my friends chevelle gauge setup:
the only thing that doesn’t work is the voltage gauge as that gets its signal from the BCM.
Old Dec 14, 2018 | 10:15 AM
Tevroc98's Avatar
Tevroc98
As I said in my original post. I’m just starting the engine in the chassis. NO body. I’m just making sure everything is good before droppingthe body. I have a dakota dash for the car but don’t want to use it till I put the nody on.
Old Dec 14, 2018 | 10:57 AM
Gordy M's Avatar
Gordy M
you can use this link for one that is OBD2 based: http://www.scantoolsoftware.com/gm-scan-tool.html#chevy
they run from $140 to 180 depending on years
Old Dec 14, 2018 | 11:04 AM
Gordy M's Avatar
Gordy M
Old Dec 14, 2018 | 06:45 PM
dbgoodwin's Avatar
dbgoodwin
Well to be fair you didn’t really explain that you just wanted it for a brief period to check before you put the gauges on.
With that said just rent the one from Autozone. The best one has a ton of features and you get all your money back when you’re done.
Old Dec 14, 2018 | 09:26 PM
Tevroc98's Avatar
Tevroc98
dbgoodwin, Thanks I'll look into that tomorrow. I never thought of them having a scan tool.
To Scan Tool
