Column Lock Bypass Kit
Old Mar 30, 2019 | 10:36 AM
DanMos's Avatar
DanMos
1st Gear
Default Column Lock Bypass Kit
Does anyone know what the exact column lock bypass kit I need to buy for my 04’ is? I’m sure it’s on here multiple times but I didn’t see it.
Old Mar 30, 2019 | 10:56 AM
Smoken1's Avatar
Smoken1
Lmc5
Old Mar 30, 2019 | 12:32 PM
rrwirsi's Avatar
rrwirsi
above post. The LMC5 is made by ComplianceParts.
http://complianceparts.com/lmc5unlocker.html
Old Mar 30, 2019 | 12:45 PM
Jackie N's Avatar
Jackie N
What's a reliable way to tell if my 01 had work done prior to my ownership which would exclude me needing this kit?
Old Mar 30, 2019 | 12:48 PM
rrwirsi's Avatar
rrwirsi
1. With key out, can you turn the steering wheel from side to side without it being locked. If no, you need the LMC5.
Old Mar 30, 2019 | 02:01 PM
Jackie N's Avatar
Jackie N
Thanks I'll try it. Have there been other fixes available over the years which would still keep the lock functional?
Old Mar 30, 2019 | 02:33 PM
MikeG37's Avatar
MikeG37
Pull the access panel in the passenger side foot well, if you don't find one of these it isn't fixed.. no matter what else has been done.
Old Mar 30, 2019 | 02:37 PM
c4cruiser's Avatar
c4cruiser
You may want to go to a Chevy dealership and ask if they would print a Vehicle Service History report for your VIN. GM did install a Column Lock Bypass for C5's and if it was done, it show up on the report.
I have that GM bypass on my manual trans '02 (the original owner had it done) and so far it seems to work. I've never had the column lock when it shouldn't. never got any of the DIC messages, and I can hear the lock energize when I turn the key off and remove it. BUT, I still carry the LMC5 and tools to install it just in case. The LMC5 costs around $50 and the tech support is superior!! For those that don't have this device, GET ONE
Old Mar 30, 2019 | 04:05 PM
MikeG37's Avatar
MikeG37
I'm way too pessimistic to buy the LMC5 and just set it aside waiting to inevitably getting stranded before installing. In the comfort of my garage it was an easy job.. laying in the floorboard in some parking lot, or gas station at night fooling with it would be MUCH different.
Old Mar 30, 2019 | 05:16 PM
Jackie N's Avatar
Jackie N
Isn't it true that if you experience the lockup it could be too late for the lmc5 to do anything ? That was my impression
Defeats the purpose of carrying one around.
Old Mar 30, 2019 | 06:01 PM
mrlmd's Avatar
mrlmd
It only cost $40, takes at most a 1/2 hr to install by anyone who can read, and there is no other sure way to make sure this problem is solved no matter what else was done to the car, by GM or anyone else.
Old Mar 30, 2019 | 07:49 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
It's never too late. Call Richard at Compliance if you have any questions. Super nice guy.
Old Mar 30, 2019 | 08:46 PM
MikeG37's Avatar
MikeG37
I believe if you were to get the unlocker with the LMC5 it wouldn't matter what state of malfunction, or which dealer installed "fix" (or none) had previously been done.
Old Mar 30, 2019 | 09:22 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
If you didn't buy the C5 new..................................LMC 5 time!!
Old Mar 30, 2019 | 09:32 PM
SLO VETTE's Avatar
SLO VETTE
Do these kits ever go bad? Curious if the inventors ever did lifecycle testing.
I have one in my '04, it's been in there since brand new. Installed it the first weekend I had the car.
Forget the brand though.
Old Mar 30, 2019 | 10:21 PM
6speedsteve's Avatar
6speedsteve
The recall was never done to my car a 2003 built Nov 2002 & still functions as it should, a lot of issues have to do with battery voltage. No offense to any one here but I have no intentions of installing any bypass on mine.
Feb 06,2004Manufacturer Recall Number N040006NHTSA Recall Number 04V060Recall Status Recall Incomplete
Old Mar 31, 2019 | 12:06 AM
ncali's Avatar
ncali
Thats your decision , so who ya going to ask when you are stuck somewhere and you have a locked column. The people on this site have suggested the best advice for you because they know that this will lock up on you, your c5 isnt so special that it wont happen to you
Good luck
To Column Lock Bypass Kit
Old Mar 31, 2019 | 09:06 AM
Phanni's Avatar
Phanni
[QUOTE=6speedsteve;1599139927]The recall was never done to my car a 2003 built Nov 2002 & still functions as it should, a lot of issues have to do with battery voltage. No offense to any one here but I have no intentions of installing any bypass on mine.
Feb 06,2004Manufacturer Recall Number N040006NHTSA Recall Number 04V060Recall Status Recall Incomplete[/QUOT
You can't fix stu........ aw forget it...
Old Apr 1, 2019 | 11:16 PM
laurent_zo6
Who would not want to gamble being stuck at midnight in a darkened place with no cell phone access?
Old Apr 2, 2019 | 12:21 AM
6speedsteve
Only place my car would be at midnight is in the parking lot where I work.
