I use this in the cup holder and it works flawlessly. Twist the screw in the base mount and it comes right out. Locks in solid when in place and holds my IPhone perfectly. Cheap too
I use the same one, but I put it in one of the 2 (Travel Buddy) cup holders that mount on the passenger side.
Can you please post a pic of how you have it installed in your car?
Originally Posted by K.I.T.T.
These are the best in my opinion...and my friends and I have tried a lot. These are clean and simple, and will peel back off. I mounted this to the center console plastic next to where the radio goes. A small metal plate sticks to the back of your phone case and you just toss it on and pull it off. It holds incredibly well. You can turn phone sideways to watch something while you're waiting, or use it for gps, etc. works good
Is there a way to remove the bottom "cradle" arm or whatever you call it? From the looks of it, it will block some ports on the bottom of my phone, which I would need when in the car. On that same note, do you think the side arms are strong enough to hold a larger phone, without that bottom cradle thingy?
