Bigger wheels
Old Apr 14, 2019 | 08:48 AM
gaustins11's Avatar
gaustins11
Default Bigger wheels
So it seems there are many people who remove the stock 17-18 inch wheels and replace with 18-19 inch wheels. As I consider a wheel change, I ask you good folks, why did you go with bigger wheels and are you glad you did? Thanks!
Old Apr 14, 2019 | 09:38 AM
Budwise's Avatar
Budwise
Tire choices go up exponentially once you get rid of the 17's. I went 18's and 19's and love it. Looks better and performs better since you can get better tires.
Old Apr 14, 2019 | 09:54 AM
Edmund Iverson's Avatar
Edmund Iverson
I've seen many posts where 18's are used all around, with staggered tire sizes front and back; I've been contemplating that route myself...
Old Apr 14, 2019 | 02:22 PM
knewblewkorvette's Avatar
knewblewkorvette
I went with 18" and 19" because these wheels only came in those sizes. I love them!
Old Apr 14, 2019 | 02:59 PM
flyingmfrc's Avatar
flyingmfrc
2020 C5 of the Year Winner- Unmodified
Knewblue-
Did you also go to 30/35 tires? Did you notice any difference from the 40/45 stock size tires?
Old Apr 14, 2019 | 03:12 PM
Some go with 18/19 to help fill up the wheel well, have a better selection of tires, or because the wheels they want do not come in stock sizes.
Nothing wrong with going up in size as long as you maintain an acceptable stagger front to rear.
Old Apr 14, 2019 | 03:28 PM
Whipitnow's Avatar
Whipitnow
So obviously if you run magnesium rims you can go 18 all the way around ? any benefit to that ?
Old Apr 14, 2019 | 03:55 PM
USAZR1's Avatar
USAZR1
If you're referring to the optional magnesium Speedlines (?), you could run a pair of those rears, on the front, and would then have 18's, all around. Problem is, the rears are only 18x9.5's. Running 18x9.5's at all four corners? I wouldn't want a rear wheel that narrow.
Old Apr 14, 2019 | 04:58 PM
knewblewkorvette
Originally Posted by flyingmfrc
Knewblue-
I can't remember off the top of my head what size is on the front but I'm running a 295/35/19 on the rear. Considering I went from run-flats to non-run-flats the ride got much better. I recently put C6 Z06 shocks and C6 Z51 sway bars on, the ride stays firm around corners. Fun Fun.
Old Apr 14, 2019 | 05:21 PM
flyingmfrc's Avatar
flyingmfrc
I assume you also went to wider rims when you went to the 18/19 diameters???
Old Apr 14, 2019 | 07:52 PM
Whipitnow's Avatar
Whipitnow
I love the way my rims look, I do not like the way there is all kinds of room left over around the outside of the tires between the wheel wells. I have the stock magnesium rims.
I do not care about performance, can I run bigger tires to get rid of all that clearance ? I would like tires 2 to 3 inches taller... If I can make it work OK....
Old Apr 14, 2019 | 08:30 PM
USAZR1's Avatar
USAZR1
If you are running oem-height tires on your car now, there's not enough room to fit a tire that 2" to 3" taller.
This thread is about wider wheels, not taller tires. Start your own thread so we don't hijack this one.
Old Apr 15, 2019 | 01:26 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
You do get more choices when you go up to 18 - 19, HOWEVER, careful if you decide to go 18*12 tire choices are extremely limiting, and very pricey.
To Bigger wheels
