Oem spark plugs!
Old Apr 30, 2019 | 11:35 PM
jz94's Avatar
jz94
Originally Posted by knewblewkorvette
So confused. I need plugs and wires for my 02....I think. I only have about 36,500 miles on her but the plugs and wire are original. It has to go into my trusted mechanic for an alternator change so I figure why not do a plug and wire change at the same time.
So....do I need to replace them? If so, which part number for the plugs? 41-110? EBay has them for $22 for a set of 8. If you get a $3 rebate for each plug, I'll end up $2 ahead. Something doesn't add up
https://www.ebay.com/itm/Set-of-8-Fo...4383.l4275.c10
I just installed those $22 ebay plugs and Taylor 79203 wires (10.4 mm, nice and heavy duty).
All 8 plugs (real AC, but came from china) had to be re-gapped from .025 to .040. Don’t know what happened over there,
the packaging looked pristine....
Old May 1, 2019 | 07:35 AM
04zjimc's Avatar
04zjimc
So while we on the subject..how is everyone keeping there wires from being burnt with headers ? I have heat socks and now im wrapping them in header wrap but only 3 wires. The wires are so close with headers!
Old May 1, 2019 | 11:01 AM
jz94's Avatar
jz94
On my truck, I used this thin, silver, space-suit looking stuff that comes in rolls. A 36” x 1.25” ID roll is about $15.
I like that it fits a little loose with an air space inside.
You see a similar material over the brake lines on the C5.
I will be the guinea pig here. I don’t have headers, but using my new wires naked. Will post how they hold up.
Old May 1, 2019 | 03:35 PM
David Webster's Avatar
David Webster
You can buy a set of 41-110 ac plugs on Ebay 20.00 a set
_
