please help stop the weirdness--long
You'd probably get better assistance over in the C5 Tech section.
Otherwise it may well be a harness issue, just pins that are no longer making great contact. Take each harness out, and see if it has the proper mechanical resistance to a pin you insert, see if it grabs it properly. See if any are just blatantly hanging loose or have big gaps.
Failing that, it may be a broken solder joint on one of the PCBs of the various modules. That's more annoying. You'd basically need to take a box out, open it, inspect the PCB for cold / broken solder joints, and reflow as necessary. You'd take the occasion to - obviously - inspect for and clean corrosion, as well, if present. Annoying and laborious.
This problem has been extensively documented by Bill Curlee and you can read more here. It is usually caused by bad contacts in a connector within the doors' rubber accordion and, since you mentioned that symptoms appear and disappear after hitting bumps, it's very likely what's affecting your car.
The female pins of the connector on that wire harness get deformed, causing bad contacts and isolating the door control module (rendering the windows inoperable). In addition to that, this could also cause a loss of communication/corruption in the Serial Data Bus affecting all modules linked by it (this would explain all messages you temporarily got after hitting a bump).
Check the connectors in both doors for deformed pins. If bad pins are found you would need to repair the connector, fixing the female pins so they have a positive grip, or replace it. If you want to replace the connector take a look at this post for some ideas.
If connectors are fine, then the problem could be downstream the connector up to the door control module, but usually it's bad contacts in the connector.
