Buying for future use
I think pretty much everything wears out with time; rust, dust, air pollution, animals, mishandling (dropping), temperature, and many more factors are involved. BUT, I'd concentrate on items that are exclusive (or almost so) to the Corvette. Headlight motors/gears; ECBMs, PCM's, etc.; switches (window, seats, etc.); things that are subject to heavier wear than your license plates. But if you're thinking about electronic parts, why not add in the other parts (radiators, transmissions, differentials, turn signal/headlight/wiper/multifunction siwtches), door handles, etc.)? I'm new to my C5, but in respect to things wearing our or giving out, there are lots of parts that will go away and parts off a Chevelle or Pinto won't fit the hole, carry the load, do the job. Just my thoughts................................ ...OregonDan
My 03 vert is a toy and not needed on a daily basis so I will worry about it when something breaks.
If it was a daily driver and I needed it I might think about buying some things. Probably not though..
My question would be if buying something used how would you test it? Install it on a good running car?
Same thing with something new because I have taken new stuff back because it was bad.Quality just isn't there a lot of times.
I think I will wait until it breaks and fix it at that time.
Just do what you think you need to do if it gives you peace of mind!
Good luck!
