Buying for future use
I’m new to forum and recently bought my first vette, a 2000 with 65k miles. I really enjoy it. It’s appears well maintained and runs wonderfully. I’m aware of the EBCM and position sensor but every for-sale replacement seems used. And not cheap! How can one hedge against possible future need, secure a decent unit today and protect against inflation as supplies thin? To be more succinct; where would a seasoned forum member suggest I look to reliably source EBCM, position sensor electronic parts today? Or is a “If you don’t need it, stop worrying,” approach as prudent?
For all the comedians on here, thanks for the laughs but be sure to keep your day job.
Now for those who don't have attention deficit disorder, I will repeat my original question:
Do electronic components go "bad" if not installed and used in a timely manner? I can make a drawing if some still have a problem with this question.
You have a completely legit question. A starter in particular is not something you need to buy spares of now. They won't stop making them, they have a nearly infinite shelf life if stored properly, and aftermarket solutions are often better and lighter. A used (installed) starter will almost certainly fail before one you pull new of the shelf. So why store it? Make that RockAuto's problem.
Electronic components don't usually go bad when stored properly, so use the antistatic bags for ESD protection*. They are more likely to be damaged during installation or use, especially if the original cause of the failure is not addressed during the repair (frayed wire shorts, for example). The EBCM issue looks to be a manufacturing defect that you can repair yourself:
https://www.corvetteforum.com/forums...r-fleabay.html
With twice as many years to age out as a C5, the replacement parts that plague a C3 are seemingly simple things like the headlight switch. It is often better to rebuild 40 year old parts than buy new replacements. Reproductions are available, but are often garbage quality. If you want to stock up on spare parts (ensuring that you'll never need to use them), pick up some OEM NOS wear items, such as switches, turn signal switches and stalks, the aforementioned throttle position sensor, etc.
*Batteries, of course, do go bad. And during the late 90s, many electronics manufacturers were affected by the Capacitor Plague.
A parts car is the only way to go as a reliable source of parts, and few would want to go that deep, borderline hoarder with a scrap car on display, for a car that will never be rare. I plan on storing my unknown future needed parts down at the junk yard, like most folks, when new is not possible.
It might be that the amount of these cars on the road, and the interest in them, will help keep them a viable market for parts . Witness the new horn sensor that just was announced for sale in the c5 section here. . It used to be strictly do it yourself, built out of blood pressure cuff parts, or something like that, and personally, I wasn't looking forward to building a reliable part out of stuff designed for other tasks, and not for cars with high interior temps, when the need struck.
Electronic parts are probably never going to be available, as GM printed all the electrical circuits out on paper, and copyrighted them to prevent any aftermarket copyright infringement. Gm is primarily interested in selling new cars, not customer support beyond warrantee limits. the company would rather spend on lawsuits from a few dead customers than spend sixty cents on a better ignition switch, if one remembers the not so long ago headlines, so don't expect a lot fo concern for your low profit needs. if you want parts support forever, that is why people will always buy an old Mercedes over a cheaper ford.
I plan on rolling the dice as I go along, and hope junk yards will have tons of unwanted parts as the cars age out of common use. I might age out of common use myself by then, so , no worries. Besides, the group mind on corvettes is pretty strong, they can build horn buttons out of scrounged parts when needed, for one example.
