Need a Battery for my 99,FRC....Dont drive it much, have a Trickle charger on it all the time...Last 6 years, been using the red top Optimal batters..There ****..Want a battery that will LAST?...Thanks....
JHrinsin
close
- Member SinceSep 2017
- LocationAvon Lake OH
Liked:685 Times in 522 Posts
This should be in the Tech section, but...
Read these treads, but I would recommend a group 78 AGM battery
https://www.corvetteforum.com/forums...placement.html
https://www.corvetteforum.com/forums...-a-c5-z06.html
Corvette-Dan
close
- Member SinceJan 2005
- LocationLyons Il
- Veteran Field #12023 C5 of the Year Finalist - Unmodified
Liked:201 Times in 125 Posts
Quote:
6 years on these cars is awesome. My Optima in my 99 just turned 6 and still going. It has outlasted everything else I've used by at least 18 months. I've owned the car 14 years.Originally Posted by clutch1
glbeauchamp
close
- Member SinceJul 2006
- LocationDouglas County WI
Liked:474 Times in 330 Posts
Yes. six years is probably over expected life, although I had an OEM AC Delco battery in a 99 Grand Prix that lasted 11. That car is hardly driven and has a tender hooked up all the time.
pewter99
close
Interstate....best thing I had in my C5 and the warranty is great
My first car had a interstate battery that lasted 12 years. Skip years ahead and I purchase an Optima red top for my C5. It lasted 4 months. They made it up but the replacement made it 9 months. You would think for the price you would get peace of mind. I'm sure people out there has had great luck with them and think they are the best thing ever. This is just my opinion with the experience that I've had. Also a friend told me not to buy it. Sometimes you have to make your own mistakes. My c5 now has an interstate battery with no issues for 4 years.
glbeauchamp
close
Highly recommend you get an agm (absorbent glass mat) battery whatever brand you settle on.
close
- Member SinceMar 2001
- LocationIn a parallel universe. Currently own 2014 Stingray Coupe.
- Veteran Field #1C7 of the Year - Modified Finalist 2021
- Veteran Field #2MO Events Coordinator
- Veteran Field #3St. Jude Co-Organizer
- Veteran Field #4St. Jude Donor '03 thru '25
- Veteran Field #5NCM Sinkhole Donor
- Veteran Field #6CI 5, 8 & 11 Veteran
Liked:24,661 Times in 17,523 Posts
Moved to C5 General.
Explorerrwirsi
close
- Member SinceNov 2014
- LocationHavre de Grace Maryland
Liked:1,339 Times in 857 Posts
Batteries are a car maintenance item just like oil. How many of us stretch changing the oil to the maximum time/millage and over. I learned that changing the battery every 5 years or before prevents the no start issue.
Saying that you want a battery to “last” is a pretty loaded sentence. What is considered lasting to you? Practically speaking there are only about 3 or so manufacturers of batteries that are just rebranded.
knewblewkorvette
close
- Member SinceMay 2003
- LocationIowa
- Veteran Field #1St. Jude Donor '03 thru '26
Liked:2,983 Times in 1,772 Posts
Quote:
https://www.corvetteforum.com/forums...rchid=78435371
Quote:
I have an Interstate battery in my Vette now. I had a Optima Red Top battery in my Vette but because I only drive the car on weekends, the battery would drain down and my radar detector would show "low volts". If you drive your car daily, this probably won't happen.Hope this helps.
I currently run a Duracell agm from Sam’s Club, it’s goin on 6 years as well but it stays on a battery tender when not being driven. The previous battery was a optima red top and it had to be replaced twice under warranty before I switched brands. Although this car maybe gets 3000 miles a year put on it max.
I had an Interstate Mega-Tron Plus (MTP) in my C5 for just over 10 years. It finally died a couple months ago so I got another one. I keep the battery connected and its on a Battery Tender Junior over the winter months. This keeps the battery at a full charge and ready to go anytime.
B-STOCK
close
- Member SinceJan 2002
- LocationRI
- Veteran Field #1St. Jude Donor '14-'15, '17, '19
Liked:36 Times in 30 Posts
I went 15 years on my factory C5 battery. Still operated like new but I won a new one at a Chevy dealers Corvette show. Would have loved to see how long the original would have lasted.
Quote:
hate to say it, but this is how battery leaks happen and how pcm’s get ruined. Batteries should be replaced every 5-7 years no matter what condition they are in. 3-5 in warmer climates aka Arizona. Originally Posted by B-STOCK
B-STOCK
close
- LocationRI
Quote:
I agree but I was so caught up in this I took the chance. Running AGMs in all of them now. Originally Posted by STRMLNE
