Agm battery
Old Mar 11, 2020 | 11:31 PM
02torchred's Avatar
02torchred
Modern lead acid batteries can and/or will leak. In my field, I've see it at least a hundred times the past 7 years, if not more. They leak either out of the vent caps, vent holes, and/or most commonly around the base of the lead post(s) (or side terminals) where the metal is surrounded by the plastic case and expand at different rates from the heat. Then they can corrode the terminals, hold down brackets, and in our case, the frame/battery tray components.
AGM are absorbed glass mat, and are the technology used in Optimas. They are not gell cells. AGM use fiberglass electrolytic sheets instead of water and sulfuric acid.
If you're not gunna use an AGM, then do a regular check up to see if it's leaking. Sometimes you cant really tell though, the water/acid mixture can run down the side of the battery, pool at the bottom or in the terminal and it will be a gradual corrosion.
Old Mar 12, 2020 | 12:59 AM
jim993's Avatar
jim993
I did not know that 2004 Corvette batteries are top terminal batteries. My 2001 is side terminal and has a three year old Red Top. In my opinion side terminals are more troublesome than top terminals.
My '84 Toyota ranch truck has a top terminal Yellow Top, now 9 1/2 years old and my horse trailer has a 9 year old Yellow Top, both going strong.
Old Mar 12, 2020 | 04:17 AM
Kingtal0n's Avatar
Kingtal0n
Surprised nobody mentioned mighty max, the ebay sealed lead acid manufacturer (and other types).
I've used a very small battery of theirs, I think 18AH, it was like $28 shipped or $32 shipped or something, it cranks over the 5.3L V8 for 3 years no issues.
I picked up a slightly larger unit for the inevitable and its less than half the size of a normal battery you get at walmart or whatever.
Old Mar 12, 2020 | 06:49 AM
kemosabe's Avatar
kemosabe
I got an ACDelco AGM from Summit Racing shipped for $120.
Old Mar 12, 2020 | 07:43 AM
04zjimc's Avatar
04zjimc
Also the battery I have only has a 90 Rc. I also have a stereo system and wanted something better!
Old Mar 12, 2020 | 08:57 AM
C5 4 ME's Avatar
C5 4 ME
Originally Posted by Fcar 98
I put a red top in my car less than three years ago. After sitting a little over a month it was stone dead. This has never happened to me with a covenantal battery in 22 years. It happened twice with five year old battery That sat for much longer than a month. The tender would not bring it up, had to have it charged that did bring it back. So we'll see what happens with it going forward. I don't use a tender when it sits for short periods. I've never had one go dead with in a months time. Not happy with the red top.
Similar story with my vette. Put in a red top and wasn't able to drive for about 10 days and the battery was dead. Took it back to my mechanic and it would not take a charge. He put in a conventional battery and I'm not having a problem now.
Hope this helps
C5 4 Me
Old Mar 12, 2020 | 09:23 AM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
I can't wait until Lithium Ion batteries become more affordable. Currently around $800: https://antigravitybatteries.com/pro...tive/ag-75-rs/
When these drop to around $300, I'll bite. But may take a few years.
One of the easiest ways to shed weight on a car, especially on the front end. 40lbs lighter than a conventional battery.
Old Mar 12, 2020 | 12:38 PM
Life’s good C5's Avatar
Life’s good C5
Regarding: the ACDelco agm for 120.00
damn that’s not bad, with my military discount I paid 174+tax.
Old Mar 12, 2020 | 01:02 PM
ShagVette's Avatar
ShagVette
Currently shows $167.99, how did you get that price?
Old Mar 12, 2020 | 01:30 PM
mtncornercarver's Avatar
mtncornercarver
Get a Deka made in USA. great battery!
Old Mar 12, 2020 | 02:03 PM
jjc508520's Avatar
jjc508520
When the Sears near me went out of business I got the "top of the line" Die Hard AGM (at a huge discount) and keep it on a "Battery Tender" brand charger and its been working out OK. Please no Die Hard critics - I know the knocks - but couldn't resist the price. Also put underneath it one of these "acid-neutralizer" mats...
Old Mar 12, 2020 | 04:58 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
When the first "leaky battery scare" hit, in 2002, I replaced the battery in my '01 C-5, with an Optima Red Top. That's all I've used in the car ever since. No, the one in there now isn't the one from 2002, but in the 2-3 times I did replace it, over the years, I moved the old one "down" to whatever my DD was at the time.....
Old Mar 12, 2020 | 06:18 PM
  #33
ncali's Avatar
ncali
Knewblew : there is a battery dealer on west capitol ave that wholesales new batteries to the public . Great deals on any battery you need
Old Mar 15, 2020 | 05:16 AM
  #34
Jistari's Avatar
Jistari
Look, Im not making any money off this :-)
I only state what Ive learned in the ten years I had a C5....
Put an AGM battery in your car.....it certainly wont hurt......
If you want "happy motoring" just make sure it has an RC of 120 or greater and I recommend a smart battery maintainer (like the CTek).
Old Mar 15, 2020 | 09:10 PM
  #35
Personally I would go with an AGM battery if nothing else for the security of it not leaking on the electrical/vacuum items under the battery tray. AC Delco should have one that fits just fine and will give good service.
Old Mar 15, 2020 | 09:57 PM
  #36
04zjimc's Avatar
04zjimc
I went with the yellow top agm 120 R/C. Hopefully this one works out. What trickle charger would be best for this battery? Thanks!
Old Mar 16, 2020 | 08:55 AM
  #37
leadfoot4's Avatar
leadfoot4
Optima makes a couple of chargers that are specifically tailored to use on their batteries.
To Agm battery
Old Mar 16, 2020 | 10:07 AM
  #38
knewblewkorvette's Avatar
knewblewkorvette
Yeah, I have the bigger one as it will bring batteries back from near dead status. I have regular ol Deltram Battery tenders on the other Optimas and they do just fine
Old Mar 16, 2020 | 01:14 PM
  #39
leadfoot4's Avatar
leadfoot4
That's what I have.
Old Mar 19, 2020 | 04:39 AM
  #40
drseth's Avatar
drseth
I was very recently shopping for an AGM battery, for my Jeep Grand Cherokee. NAPA sells an AGM, made in the USA by East Penn Battery Co, and Champion (formerly just a spark plug supplier) also markets an AGM battery, sold in many auto parts stores, including Pep Boys. I wound up going with the Champion, although not through Pep Boys, but rather an auto parts wholesaler, where an old friend works. The main reason I went with the Champion is because it was highly rated, and considerably less than the NAPA battery.
Having said all this, I can't vouch for either NAPA or Pep Boys stocking an AGM in Corvette sizes....
I have not had good luck with East Penn AGM batteries. 2 AGM batteries in my boat crapped out after only 3 years. I also had to replace my Corvette AGM battery after 2 years, despite having a float charger connected.
I had a red top optima that lasted 11 years. I would go with an Optimal.
