quality window regulator?
Old Jun 1, 2020 | 12:05 PM
forango's Avatar
forango
Default quality window regulator?
I see online there are multiple options and price ranges for driver's side window regulators with motor...is one better than the others? I want to get something that will work, but still pay a reasonable price
Old Jun 1, 2020 | 03:18 PM
Simtech's Avatar
Simtech
I replaced mine a year ago with this one from Amazon and have had no issues with it. Installation it pretty strait forward, just make sure you mark everything and it shouldn't need much adjustment when you are done.
Power Window Regulator With Motor Assembly Front Left Drivers Side Replacement fit for 1997-2004 Chevrolet Corvette 10338548
by
cciyu cciyu
Price: $55.07 & FREE Shipping
Old Jun 1, 2020 | 09:49 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
The cheapest ones (seen as low as $33) are as good as the OEM.
Worked at a Corvette-only repair shop buying all parts. We changed maybe 4 per month and zero came back even years later as defective.
My C5z is mint, and if I needed a regulator I’d 100% buy the cheapest one.
Old Jun 1, 2020 | 09:50 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Some things you always buy factory or other option paying for quality, the regulators aren’t one of those items.
Old Jun 2, 2020 | 09:05 AM
forango's Avatar
forango
Thanks for all the info....I ended up grabbing one off Amazon for 50 bucks just cause I needed it before this weekend
Old Jun 2, 2020 | 09:31 AM
tommie's Avatar
tommie
When i replaced mine I bought an AC Delco regulator. There were posts on here saying the cheaper aftermarket ones did not last, so I payed a little more for the Delco. I have not had any issues with the replacement window regulator
Old Jun 5, 2020 | 04:30 PM
stingray76l82's Avatar
stingray76l82
Default Cheap regulator
I bought One from Rock Auto not OEM. Worked ok slow going up and down. Bit of a issue with wind noise. Took it to the dealer and getting coolant change and ejectors cleaned had them take a look at the window issue. They said you have A/M regulator the did fixed for a couple of days. So I bought OEM window Regulator. What a huge difference . Rolls up faster and no wind noise. Lesson you get what you pay for.
Old Apr 11, 2025 | 03:41 PM
ToddC52003's Avatar
ToddC52003
1st Gear
Default Dorman was junk
Sad story first. I bought a C5 Corvette with 3400 miles took it to the Corvette Fairway dealership here in Vegas to change fluids. Something fell on the window chipped the top of it and messed up my regulator. They replaced it with a O'Reillys Dorman 748–472. With the window up the door open the window is sloppy. With the window down you get air noise and the speaker is vibrating the window. Determined the problem was with the little green things that ride up and down the track having too much play. now I'm looking for a replacement.
To quality window regulator?
