Vararam coupling?
Old Aug 10, 2020 | 09:50 AM
QuiksilvrZ's Avatar
QuiksilvrZ
Default Vararam coupling?
I bought my VR-B2 used and it came without the coupling that goes between the filter box and the MAF. My car being an '02, I figured that any old 3.5" silicone coupler off of Amazon, cut to fit, should work with my 85mm MAF. Should this be ok?
Old Aug 10, 2020 | 06:20 PM
ZEEZERO-6's Avatar
ZEEZERO-6
I hope you know that the VR-B2 does not have a carb # and will not pass the visual smog check inspection in CA. A lot of work to install then uninstall to pass smog - just saying, but you may already be aware of this ?
Old Aug 10, 2020 | 06:28 PM
QuiksilvrZ's Avatar
QuiksilvrZ
I know what I'm getting myself into. I have several lifts to make any such job much quicker.
Old Aug 10, 2020 | 07:17 PM
zeevette's Avatar
zeevette
My VR had a 4" coupler.
Old Aug 10, 2020 | 08:06 PM
Bob_VII's Avatar
Bob_VII
If you need the smog place that didn't care about my Vararam let me know.
Old Aug 10, 2020 | 08:39 PM
QuiksilvrZ's Avatar
QuiksilvrZ
I thought 4" ID might be too large for the 3.35" MAF. Should I try to find 3.75? 4.0 and 3.5 are easy to find but 3.75 not so much.
Old Aug 11, 2020 | 08:12 AM
Gordy M's Avatar
Gordy M
You might think about keeping the stock accordion coupler rather than a smooth one. Other than looks, it does nothing to the performance but often requires a slight tuning adjustment....the accordion coupler turbulence was part of the original non-programmable firmware in the PCM. Over the years some had problems on decel with popping and accel with lag.
Old Aug 11, 2020 | 08:37 AM
c4gone's Avatar
c4gone
Interesting. I didn't know any of that
Old Aug 11, 2020 | 09:14 AM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Maybe my 04 was more sensitive to the Vararam but my car needed to be tuned. I was getting the lean codes with the stock coupler as well as with the power duct. After turning it seems to be working fine. After you install the Vararam just take a look at your fuel trims. If they are too high after driving for a few hundred miles you may need a tune.
Old Aug 11, 2020 | 09:28 AM
QuiksilvrZ's Avatar
QuiksilvrZ
The coupler in question is the one between the MAF and filter, not the bridge and the TB. I'm just trying to find out what size to get. I've installed headers and a ported TB at the same time and I've already mailed my PCM to ECS.
To Vararam coupling?
