95k
OG motor, trans replaced (loss of 5&6 gear) had loss revers at around 175,000, cause: we have a steep drive way that we back up. All the other bit that need replacing or fixing, steering sensor, re-solder climate control board, TCM fixed, oil pressure sender, AUX air valves and pump (didn't really need the pump) torque tube (I messed up the impute and pilot bearing) TT was easer to find the a new/use impute. One (right side) Ti muffler developed a crack and blew out the end plate (had it fixed but found a new set at a reasonable price so I have a pair set). On day one new, installed JRZ DA shocks, will rebuild this winter but they are still working as designed and don't leak gas. Column lock failed in year two, on grid a National Tour (killed a great day) A month in from new and two Solo Two day and the front A arms upper/lower need replacing (uppers move forward lowers moved back) this happen three time in the first two month, some how the last fix has been stable ever since (I'm thinking they installed T-1 control arms) T-1 sway bar end links. I'v built my own shifter (its tall, but very short through) replaced radiator with a Dewit's, and after three years with out Air Con, replaced AC compressor and other service parts. Last but one of the best mods Raidoflyer Bi-Zeon head lights. Other then warranty years needs, I'v done all the work my self. Expendables, uncounted tires (wife freak out during national tour when she realized that I had spent $15k on tires), brake rotors by the ton and pads, just replace TieRod ends damaged boots from rotor heat. That's about it.
This car was bought new as a Solo weapon and did so for three year, then settled in to road trip car, Bonneville 150 lic car, track day lead follow instructor car. Now I just get in and drive it still looks good.
Mark.
