A tuner can turn off just that one item so that any other check engine light you would get would come on as it normally would.
Yes, that would be ideal. Does anyone know someone in the New Orleans area that would be willing to do this for me? I would obviously be willing to pay.
Rebuild it! Ask any member of the NCRS if they have any leads. I was looking for a OPTI one guy had six on the shelf! That pump should have nothing to do with service engine light but it will affect many other items and give you the service engine light.Did you check codes?
I am an older retired lady so rebuilding is not an option. (Sounds expensive.) I don’t drive that much anymore but love my car and want to keep it as long as possible. I did run codes. It was P0410.
If your go to mechanic is unwilling to do the tune out and it is because of a legal issue, do you have emission testing in LA? If not, try the joining states for a tuner that will zap the the light. Another option, just put a piece of black tape over the light so it does not bother you. I did that on a different car for 3 years. Did not bother me a bit.
No emission testing in La. I need to have the light functional so I can realize any new issues that might turn up.
Looks like there is a pretty good shop in Baton Rogue according to guys on LS1Tech, I'm pretty sure they could easily turn the AIR codes off. I ditched that whole system when I changed exhausts on mine, everything else will still work perfectly fine.
Engine Power Systems
1116 Executive Park Ave
Baton Rouge, LA 70806
