Driver's side heat control knob
Old Apr 7, 2021 | 09:45 PM
chaz2000's Avatar
chaz2000
Cruising
Default Driver's side heat control ****
Hey!
The Driver's side heat control **** spins around. Can't tell if it's actually doing anything. The passenger side does seem to function properly.
Comments? Fixes?
Thanks!
Old Apr 8, 2021 | 12:41 PM
If you have the dual zone HVAC, when you spin the **** the temp in the display should change up or down. If it isn’t, either the **** is too loose to change the temp or the HVAC unit has a problem.
Try taking the **** off and then see if turning the shaft on the HVAC unit changes the temp. If it does, your **** is the problem. You could probably find a good used one at one of the forum’s used parts vendors (Vettenuts or aescorvetteparts). Good luck - hope it is something simple.
