Purchasing a C5 from Canada
- I've heard that that the gauge cluster on the Canadian version is different (coolant temp is in C instead of F, the speedo is numbered to 300 and is in km/h, etc. I know that you can switch between km/h and mph through the DIC, but do the other readings remain in metric? I don't mind the speedo being numbered to 300 but I don't want a car that can only give coolant readings in Celsius, or oil pressure in kPa. Additionally, if I switch the car to mph, will it reset to km/h every time I start the car? I don't want to have to switch it every time I get in the car.
- As another option, I have heard that Canadian C5 corvettes are produced with a Z49(?) RPO code that designates them as Canadian. Would i be able to get somebody with a Tech2 scanner to remove this RPO code? If I did, would the car behave exactly like a US-spec model?
- Is there anybody else who has done this sort of purchase? (US buying from Canada). If anybody has, could you walk me through the paperwork and steps that I would need to take to make this transaction go smoothly? Unfortunately, I'm unable to physically go and drive the car back. How would shipping work with this? Would I give the truck driver the paperwork to give to border patrol?
- Has anybody had trouble with their state registering a Canadian car? (In my case I'm currently stuck in California, so this is a major concern as I know how strict they can be).
The other thing is the twilight option cannot be disabled, so you will have daytime running lights - which I think are a good thing all the time anyway, and a good mod to update the look. The annoying part of that option is that your headlights will automatically pop up and come on when you enter a dark space, so my lights come on for those few seconds as I pull into my garage. It’s a minor thing and I’m used to it, and I’ve read on this forum that it cannot be disabled.
I've also heard you can replace the light sensor with a resistor to disable the popups going up with twilight sentinel
