Driving shaky
Old May 24, 2021 | 07:57 PM
Georgeanthonys's Avatar
Georgeanthonys
2nd Gear
Default Driving shaky
I purchased four new tires for my C5 and when I drive 55 and over I feel my car shake like if it was wobbling every couple of seconds consistently. I check the tires they all look good their balanced the car is aligned and when I drive slow or 40 or 50 the car doesn’t vibrate, over 50, it vibrates at the same intervals every couple of seconds. Does anyone know what this could be.
thank you and looking forward to your help or suggestions
Old May 24, 2021 | 08:06 PM
1999corvettels1's Avatar
1999corvettels1
Got new tires on old Grand Am at discount tire, got on freeway car was shaking bad, took to another Discount tire next day, all 4 wheels were improperly balanced.
Also the goons at first Discount tire broke off lug stud and didn't tell me, Discount sent me to a shop and they payed them to replace the broken stud.
Lost some of the chrome lug nut cover shields, more of a for looks thing, bought more at a self serve salvage yard with a car that had same hub caps.
Did car shake before new tires?
Old May 24, 2021 | 08:31 PM
Georgeanthonys
2nd Gear
I don’t remember, I had it in storage for over 2 years. I did see that the four tires
Were dried out, so I replaced them with new ones.
I was told by the mechanic that the car looks great but it did need the tires.
Old May 24, 2021 | 08:55 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Take it back for a rebalance.
Old May 25, 2021 | 11:48 AM
knewblewkorvette's Avatar
knewblewkorvette
Old May 25, 2021 | 12:21 PM
rjacobs's Avatar
rjacobs
Originally Posted by Georgeanthonys
they're balanced
no they aren't
Old May 25, 2021 | 02:05 PM
ZigZag's Avatar
ZigZag
My car didn't shake before new tires. Soon as my new tires were mounted and balanced I went for a drive and the car shook from 45 and up. Went back and rebalanced with no luck. Went to a tire shop that had road force balancing and had that done. No more shake at any speed.
Old May 25, 2021 | 02:44 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Get them road force balanced. This will solve your problem. Also, welcome to the forum!
Don't forget to SAVE THE WAVE!
Old May 25, 2021 | 06:16 PM
rjacobs's Avatar
rjacobs
Yup road force balance... It can tell them if they need to spin the tire on the rim a little bit.
Old May 27, 2021 | 07:35 AM
WebRat's Avatar
WebRat
Cruising
I made almost the exact same post.
Going to look at getting that road force rebalance and a alignment also.
Just bought a 2001 convertible and purchased new tires and rims from a vendor here, mounted and balanced. Car has about 73,000 miles on it.
While driving on the freeway at around 60 mph I start to get a weird vibration, it doesn't feel like its in the steering wheel as much as the whole front end starts to shake.
Its not constant, more like if you say out loud, "one, two, three, four, smooooth" then it repeats.
Old May 28, 2021 | 12:56 PM
mkraffert's Avatar
mkraffert
St. Jude Donor '20
I had that happen to me once 'back in the day' when I put some Sears radials on my 280Z. Turned out the tires were egg shaped, so even though they were balanced, they caused vibrations at 70MPH. Sears' solution was to remind me that the speed limit back then was 55 so vibrations at 70 shouldn't matter, and that it's illegal that I even knew it vibrated.
To Driving shaky
