Mid-Engine C5 T-70
Old Jul 22, 2021 | 12:45 AM
RSILVR1's Avatar
RSILVR1
Default Mid-Engine C5 T-70
Main floor section is about completed.
Fabricating vertical pieces FOD the side-pods. I dropped the stock biscuits on to reference engine location.
Here you can begin to see the driver tunnel, each side is 19” wide like the original T70
I have the pedal location as far forward as possible here, I’ve had to fab another 080” joggle for cradle clearance. I have the front of the pedal box 4” aft of the rack.
Upright pictures.
Pedal box will be more like an F1 can with your heels higher than you bottom. I can do anything about it using corvette pieces.
European right-Hand drive Cadillac steering rack, same internal length, ratio & it happens to just drop right on the mounts….
Popular Reply
Jul 22, 2021, 01:15 AM
RSILVR1's Avatar
RSILVR1
Old Jul 22, 2021 | 01:05 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
interesting
photos of the concept???
Old Jul 22, 2021 | 01:07 AM
pewter99's Avatar
pewter99
I'm intrigued.....subscribed and I never do that
Old Jul 22, 2021 | 01:15 AM
RSILVR1's Avatar
RSILVR1
Old Jul 22, 2021 | 01:26 AM
RSILVR1's Avatar
RSILVR1
Old picture was with 18”/19” now I have 19”/20” to clear carbon/carbon brakes…..man, this is a slippery slope….
Old Jul 22, 2021 | 08:25 AM
Robert Barcus's Avatar
Robert Barcus
I would love to spend a day with you in the garage.
Old Jul 22, 2021 | 08:41 AM
grinder11's Avatar
grinder11
I agree, but at my age it might be pretty hard to keep up! The OP must have been hyper as a child, and still might be as an adult!!! OP-Congratulations on undertaking one of the most, if not the most, ambitious C5 projects I've seen, or heard of!!
Old Jul 22, 2021 | 10:20 AM
RSILVR1's Avatar
RSILVR1
I hate seeing old stuff cast-off for junk, this chassis was a proto for something else & cast off. I said, you know…maybe I can take this,…and that,….and maybe that over there & put it all together?…..I’ve build a few cars over the years & wanted something different….
it will be a little rude, crude, and maybe socially unacceptable but it will spark a conversation.
2000lbs, 625hp 422” LS3, it should go okay.
Old Jul 22, 2021 | 12:22 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by RSILVR1
......It will be a little rude, crude, and maybe socially unacceptable but it will spark a conversation.
I see no problem with that!! All I want to know is when it will be finished, as I'd like to go for a ride in it.
Old Jul 22, 2021 | 12:41 PM
petersm's Avatar
petersm
The work of art and tec continues. What a great masterpiece.
Old Jul 22, 2021 | 01:07 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Awesome work. Coming along great.
Old Jul 22, 2021 | 02:20 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Very impressive! I can't wait to see the finished result.
Old Jul 22, 2021 | 04:27 PM
mre1974's Avatar
mre1974
one of my all time favorite projects and builds ever.
Old Jul 22, 2021 | 07:04 PM
RSILVR1's Avatar
RSILVR1
Today’s a new day, let’s do the pedal box.
Wa-La, roughed in.
Floor is 080”, sides & top are 063”, front is .100” I’ll mount the master cylinders right on it….
Old Jul 22, 2021 | 10:48 PM
Very cool project and nice work so far. Good luck with the rest of the build - keep us updated.
Old Jul 25, 2021 | 07:34 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Anything you need from the forum, feel free to ask. Guys here have resources and expertise to share and would be glad to support your project.
It seems you intend to track the car, give the brakes selected, and that more than anything else now excites me for this car. Especially since much street use will abuse the long low slung nose.
Old Jul 25, 2021 | 08:25 PM
RSILVR1's Avatar
RSILVR1
It means a lot to have everyone’s support, the project has focused more track day oriented as I move forward…I do have it titled & plated for cars-n-coffee if I feel like it I guess. It’s so..low I don’t think my wife can get in & out of it.
As I’m building footbox & instrument panel I’m already thinking of running coolant lines through the fuel bays to help cooling along with tighter packaging…
the more I look the more I see that can be improved.
I’m screwing on skid plates under the nose for protection, it’s only 3.5” off the ground like 2-feet in front of the tires…
Old Aug 1, 2021 | 01:45 AM
RSILVR1's Avatar
RSILVR1
Busted out the Kennedy adapter & hardware for everything.
Here’s some of the initial views
Buddy dropped off a bare block for me to use for mock-ups.
Better look at the first step….
3-solid days of heavy lower cradle modifications including drilling up a .375” 6061 aluminum plate to tie cradle sides together after modifications.
Heavily modified area around starter location…
To Mid-Engine C5 T-70
