Mid-Engine C5 T-70
Old Nov 9, 2021 | 11:21 PM
  #41
RSILVR1's Avatar
RSILVR1
Default 11/9 updates
422” LS-3 finally going together this week, engine GuRu finally sent me some picks…
Old Nov 10, 2021 | 07:29 AM
  #42
feeder82's Avatar
feeder82
Old Nov 10, 2021 | 11:31 AM
  #43
Tusc's Avatar
Tusc
Running Guns & Moonshine
Thought I'd mention. If you go on fb and like the Glickenhaus racing team, Jim posted videos of their actual T-70 today as they prep it for some road time.
Old Nov 10, 2021 | 12:10 PM
  #44
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Still looking great! I really look forward to your updates. Keep them coming!
Old Nov 10, 2021 | 04:02 PM
  #45
vette4fl's Avatar
vette4fl
Originally Posted by rrwirsi
Personally, I like the update Thread showing just the progress. Having to scowl down to the last update is a pain on an on-going Thread. JMHO.
Go to the “last post” column and tap the tiny arrow next to “by”, and you will go directly to the end of the string
Old Nov 12, 2021 | 11:42 PM
  #46
RSILVR1's Avatar
RSILVR1
Default 11/11 updates
I wanted to confirm body alignments begin proportionate adjustments for the stretch.
Here is a 5” stretch in the upper door/side window area that works nice with stretch. I’m trying to pull everything into a smooth look. The idea is if you don’t know T-70’s you won’t notice the stretch.
Old Nov 13, 2021 | 12:36 AM
  #47
vette4fl's Avatar
vette4fl
Wow! This s the kind of project a motorhead dreams of, but rarely has the skill for.
Your talent and craftsmanship is amazing, and I look forward with great interest as your project evolves.
Old Nov 15, 2021 | 04:46 PM
  #48
RSILVR1's Avatar
RSILVR1
Default 11/15 updates
ZR1 knuckles & rebuilt control arms with polyurethane going on finally
Bodywork back off for suspension install, coil-overs fit neat. Waiting on alignment kit, new hubs & long studs to show up.
Old Nov 15, 2021 | 07:08 PM
  #49
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
Beyond awesome!!!
Old Nov 15, 2021 | 07:59 PM
  #50
vette4fl's Avatar
vette4fl
Taking shape before our eyes!
Old Nov 15, 2021 | 08:00 PM
  #51
MikeTN77's Avatar
MikeTN77
This is amazing. The level of skill and talent required to task a project such as this is remarkable. Enjoying the updates!
Old Feb 18, 2022 | 12:38 PM
  #52
jjc508520's Avatar
jjc508520
What's the latest?
Old Feb 18, 2022 | 03:07 PM
  #53
RSILVR1's Avatar
RSILVR1
Default 2/18/2022 updates
Well,
You’ll have to wait, engine is being completed along with some suspension bits…
I’ll update with photos shortly!
Old Apr 2, 2022 | 10:44 PM
  #54
RSILVR1's Avatar
RSILVR1
Default Midengine C5 T-70 4/1/22 updates!!!!
Cradles are blasted, poly bushings installed, new hubs ready to install. Should have it off the table & a roller here in a week or two. I’ll drop in the tub & screw the floors in so I can start riveting the floor.
422” LS3 went on the dyno today….ran it with a sheet metal intake we had just because it looks more the part, the torque is a little softer but it made more power with short runners..
Thing is a tractor, should pull any gear with ease….. Target weight for the car complete is just over 2000lbs. It should knock your teeth out.
Old Apr 3, 2022 | 12:41 AM
  #55
rgsGarage's Avatar
rgsGarage
This is just awesome.
Old Apr 3, 2022 | 09:59 AM
  #56
Fast one's Avatar
Fast one
Are you going to register it as a Lola, a Corvette or something else?
Old Apr 3, 2022 | 11:08 AM
  #57
RSILVR1's Avatar
RSILVR1
Default Mid engine C5 T-70
It’s titled as a 2000 C5.
already have plates for it…..
To Mid-Engine C5 T-70
Old Apr 3, 2022 | 03:45 PM
  #58
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
I want one. Nice work sir!
Old Apr 3, 2022 | 11:02 PM
  #59
RSILVR1's Avatar
RSILVR1
Default Mid engine C5 T70
Well here we go fabricating the right-hand drive Cadillac steering rack. I’m going to be clipping off the factory corvette tabs. I’m rotating the rack about 30 degrees forward to better alight the steering shaft better. I will be trying to keep the magnet on the steering unit for variable power-steering functions if I want to wire it in the future.
This rack is exactly the same width, overall length at tie-rod pivots & ratio is just a touch faster than the factory unit.
Old Apr 3, 2022 | 11:24 PM
  #60
Tusc's Avatar
Tusc
Originally Posted by RSILVR1
Great torque curve on that. A proper NA beast.
Quick question - I noticed the screw on exhaust port covers. Where did you pick those up from? Beats duct tape any day.
