Side marker light
Old Aug 8, 2021 | 09:48 AM
Escue's Avatar
Escue
Default Side marker light
I want to replace the passenger rear side marker light lens on my C5. I’ve removed the rear carpeted compartment panel and found a threaded stud and pop rivet in the general area of the outside light. What are the next steps to replacing the light?
Old Aug 8, 2021 | 09:49 AM
TheBac's Avatar
TheBac
You access the side marker by removing the outer taillight on either side, not through the interior.
Old Aug 8, 2021 | 10:10 AM
Autoeng's Avatar
Autoeng
And it can be difficult to get the Tinnerman nuts off. The light mounting studs are plastic and the Tinnerman nuts are stamped metal and thin and sharp-edged so you have to use a socket or wrench, not your fingers when they get near the end of the stud. I didn't have one but I would think a ratcheted, closed end wrench would be best as there is hardly room for a 1/4" drive socket and you need a medium depth socket as the studs are fairly long.. Regardless, they don't ever get looser as they cut into the plastic stud. When you remove the light from the body you are likely to break the plastic studs that the nuts are on.
Old Aug 8, 2021 | 10:25 AM
ALLEGRO's Avatar
ALLEGRO
Not a hard job at all, just take your time with the fastener.
Old Aug 8, 2021 | 07:54 PM
Escue's Avatar
Escue
Thank you! Removing the outboard taillight would have never occurred to me.
Old Aug 9, 2021 | 02:22 AM
03 Owner's Avatar
03 Owner
If you have a convertible the right side is accessible by removing the inner fender. You can't get to it through the tailight because of the power antennae. Sounds harder than it is just remove right rear tire and all the screws are accessible to remove inner fender. Remove it and the side marker is easily accessible. Left side is easy through tailight. Thread the nuts on before installing to make threads on plastic stud then remove nuts and install side marker. This makes it easier to start nuts on in the right space you will be working in.
Old Aug 9, 2021 | 05:45 AM
Escue's Avatar
Escue
Not a vert, but thanks for the tip of getting the studs pre-threaded.
Old Aug 9, 2021 | 08:20 AM
All good advice. And be sure you do not over-tighten the attachment nut - doesn’t take a lot to snap the stud off the light.
Old Aug 9, 2021 | 01:00 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I agree with all the advice given so far. The one other piece of advice is to make sure the the fasteners are lined up straight with the studs. It's not like with a nut and bolt where they just line up. Since the fastener cuts into the stud, it is possible to get in on crooked. Then it will not apply even pressure on the back of the body panel. It will likely still hold, but it also increases the chances of breaking the stud. Go slow and be careful.
Old Aug 9, 2021 | 02:52 PM
Autoeng's Avatar
Autoeng
I snapped one of the studs on mine and had to use 3M tape to hold it in. Works fine but pissed me off.
Old Aug 11, 2021 | 10:10 AM
jjc508520's Avatar
jjc508520
I never knew there was a name for these!
Old Aug 13, 2021 | 09:37 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
I just did mine. The right side marker on the vert is accessible through the right outside taillight by removing the two nuts that hold the antenna and then slipping it down through the grommet. Then push the antenna to the left. No need to go under the car.
Old Aug 17, 2021 | 07:20 PM
old stingray's Avatar
old stingray
Old Aug 18, 2021 | 06:10 AM
Escue's Avatar
Escue
I only had to replace the passenger side on my Coupe. Thanks to all of you for making it a super easy job.
To Side marker light
