C5 shock replacement
Old Aug 12, 2021 | 07:19 PM
Rick03C5's Avatar
Rick03C5
7th Gear
Default C5 shock replacement
Going to change out FF55 shocks and eliminate magnetic ride control.Looking at Billsteins for replacement.Advice from anyone who has done this would be appreciated
Old Aug 13, 2021 | 02:14 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by Rick03C5
Going to change out FF55 shocks and eliminate magnetic ride control.Looking at Billsteins for replacement. Advice from anyone who has done this would be appreciated
...i replaced my shocks with C6 Z06 shocks...
Old Aug 13, 2021 | 10:15 AM
helga203's Avatar
helga203
Old Aug 13, 2021 | 10:35 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
+1 for the C6 Z06 shocks. Swap out for the C6 Z51 sway bars while you're at it.
Old Aug 13, 2021 | 11:13 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
I did that also...
Old Aug 13, 2021 | 11:21 AM
acroy's Avatar
acroy
You have chosen wisely
Old Aug 13, 2021 | 12:20 PM
SilverC54me's Avatar
SilverC54me
You will need a Tech2 to disable the F55 system. The simulators available do not last.
Gary
Old Aug 13, 2021 | 01:25 PM
MWWarlord's Avatar
MWWarlord
Gary
Correct, you will need a tech II...Simulators don't work at all with the F55. They only work with F45.
Old Aug 13, 2021 | 01:37 PM
C6 Z06 shocks are a good way to go.
Old Aug 13, 2021 | 03:36 PM
c5arlen's Avatar
c5arlen
What is the problem with replacing an FF25 an FF25? I don't get it!?
Old Aug 13, 2021 | 05:52 PM
Smoken1's Avatar
Smoken1
We don't get it either
Old Aug 15, 2021 | 05:22 PM
FrankLP's Avatar
FrankLP
Miles of Smiles
2016 C5 of the Year Finalist
Same here. A popular and solid mod.
Old Aug 16, 2021 | 03:50 PM
bc6152's Avatar
bc6152
I want to replace my 1998 F45 system with Bilstein shocks and have a question about use of the Tech 2 computer. Is it simply a matter of the Tech 2 operator finding a list of options on your car and selecting "delete" and it's done? Then replacing the existing shocks with the new ones? Sounds too easy...
Old Aug 16, 2021 | 03:58 PM
MWWarlord's Avatar
MWWarlord
The tech II is used to delete the F55 shocks (and yes it is that easy). I believe that simulators are needed for the F45.
Old Aug 16, 2021 | 05:18 PM
Smoken1's Avatar
Smoken1
1. Hook up Tech 2, turn car on, make sure module in the rear is plugged in. Do not unplug the rear module.
2. Use Tech 2 to delete the F45 option (F55 does not appear on the menu screen, use F45).
3. Save new configuration.
4. Do not turn car off, do not remove Tech 2. Go to the module in the rear of the car, unplug the grey connector (the widest one), leave any other plug(s) in. [leave the other 1 (F45) or 2 (F55) plugged in]
5. Turn off car, leave Tech 2 plugged in.
6. Remove remaining plugs from module in the rear of car. [never plug them back in again, if you do the F45 turns on automatically]
7. Turn car on to verify the "max speed 80 mph" is gone.
8. Unplug Tech 2.
Old Aug 16, 2021 | 05:34 PM
bc6152's Avatar
bc6152
OK Thanks Smoken. Just two more questions... Where is the "rear module" located, and does a '98 require simulators? I just want to seem like I know what I'm asking for when I get this done. Thanks for the help it is much appreciated...
Old Aug 16, 2021 | 05:48 PM
K9Leader's Avatar
K9Leader
It is in the driver side storage bin, covered with carpet. If you have the F45 deleted with a Tech II you will not need simulators. If you don't/can't use a Tech II to delete the F45, then the simulators are to fool the system into thinking the F45 shocks are still present. I pulled my F45s out of my '99 several years ago for C6 Z06 shocks. My F45s were still working but I, frankly, could not tell any difference among the three settings (maybe could have on a track but mine is a convertible so getting on a track was unlikely), saw how much they would cost to replace, and had an opportunity for a great deal on C6 Z06 takeoffs with less than 500 miles on them. I also got lucky that Carlisle was coming up and a forum member (Bill Curlee) offered to use his Tech II to delete the F45 while at Carlisle - this was in 2012 (or 13?).
To C5 shock replacement
Old Aug 16, 2021 | 06:06 PM
bc6152's Avatar
bc6152
Thanks a lot K9. All questions answered and am ready to go forward.
Old Aug 16, 2021 | 06:16 PM
Smoken1's Avatar
Smoken1
When I did it I also cut off the connectors from the old shocks and plugged them back in to keep water out of my main harness
Old Aug 16, 2021 | 06:20 PM
bc6152's Avatar
bc6152
Sounds like a good tip. Thanks again Smoken...
