[Z06] Window leak
Old Dec 26, 2021 | 05:20 PM
Z06Berlin's Avatar
Z06Berlin
Default Window leak
I just had my windows adjusted and the driver's side back is still leaking. Do I need to replace the seals? Thanks for your help.
Old Dec 26, 2021 | 05:46 PM
Old School's Avatar
Old School
You need to carefully check exactly where the water is coming thru. The FRC are known to leak between the plastic reveal moulding and the body(roof)..
https://www.corvetteforum.com/forums...roof-leak.html
Unless the weatherstrip is cracked or ripped my guess is it's probably ok
Old Dec 26, 2021 | 06:31 PM
Z06Berlin's Avatar
Z06Berlin
It is coming through at the upper corner. When I am driving I feel air coming through the corner.
Old Dec 26, 2021 | 08:09 PM
Old School's Avatar
Old School
Does it seem like there is a gap between the window and the weatherstrip? The rear upper corner is also where the reveal moulding often leaks. The glass is easy enough to adjust once you remove the interior door panel if you want to try to adjust it yourself.
Old Dec 26, 2021 | 10:14 PM
Autoeng's Avatar
Autoeng
Check out my thread on my leaking driver's window. does your window alignment look like mine did? If so, you have to remove the inner door panel and adjust the glass in the regulator.
https://www.corvetteforum.com/forums...t-tilt-in.html
Old Dec 27, 2021 | 06:24 AM
Z06Berlin's Avatar
Z06Berlin
I had the window adjusted at the shop a couple of weeks ago and they said everything is fine. They are now closed for the holidays. Will take it back next year.
Old Dec 28, 2021 | 08:37 PM
I would take it back and ask that they try and adjust the window to where it seals completely. Good luck and hope they can help you out.
Old Dec 29, 2021 | 11:37 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I agree. If you already paid a shop, you should make them correct the problem. It sounds like you certainly need adjustment. However, you can put dielectric grease on the seals. This may help a bit.
To Window leak
