what headers do yall recommend
Old Aug 12, 2022 | 12:48 AM
Karma.Ambushh's Avatar
Karma.Ambushh
Default what headers do yall recommend
I have a 03 c5 50th anniversary and I am just not sure what headers I should get as well as sizing. I dont want to order some and mess up the sizing and have to re order new ones. I was looking at american racing long tube headers as ive heard good things about them. price wise im not sure what good headers go for but the ones I looked at were 2100
Old Aug 12, 2022 | 03:31 AM
Smoken1's Avatar
Smoken1
ARH or Kooks are great headers. I have Kooks and I paid 2k for catted 1 7/8's coated headers
Old Aug 12, 2022 | 03:46 AM
ariZona06's Avatar
ariZona06
I have LG 1 3/4" long tubes that were installed by the previous owner. BUT before to go out and grab "a set of headers" what are your performance goals for your vehicle? Any other MODS? Are you auto trans or manual? Headers are a good part of a comprehensive build so before you plunk down $2K or so you may want to establish a good plan of attack to get the most bang for your buck. Plenty of good advice available on this forum as to heads, cam and gear selection.
Old Aug 12, 2022 | 08:11 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I have ARH 1-3/4" headers and catless x pipe. Install was very easy. I got mine through DRM.
Old Aug 12, 2022 | 08:15 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
When shopping options, I get confused by the size offerings. I'm currently running a Corsa Indy Pro plus axle-back system with Corsa X-pipe. If I go with long-tube headers (with cats) I would need to lose the Corsa X-pipe correct? If so, how do I figure out the correct size to order?
Old Aug 12, 2022 | 08:23 AM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Lots of people rave about the Speed Engineering headers.
https://speed-engineering.com/produc...e-stainless-m2
Old Aug 12, 2022 | 08:42 AM
oh1vette's Avatar
oh1vette
I went the budget route and have XS Power headers, no issues after 7 years...
Old Aug 12, 2022 | 09:10 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Kooks, directly recommended by my mechanic "TunedbyFrost", who has installed ALL of them.
1 3/4 if you will stay naturally aspirated.
1 7/8 if you are every considering forced induction.
Old Aug 12, 2022 | 09:13 AM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
2k for steel tubing is stupid. Better fitment or not, its not justified. The R&D doesnt justify it either its not a space shuttle, its an 18-25 year old car. Once on the Dyno, theres a marginal difference between brands and individual cars. Its too little to notice while driving. What it comes down to is quality steel, and fitment that is leak free. The cheaper brands dont fit as well but they do fit. If you are a competent DIYer, get the cheap ones. Just make sure the company is using the good steel and has decent customer service. I always try to get someone on the phone or through email before I use a company, just as a test.
I can personally vouch for Texas Speed and Performance (TSP) headers. I have them on my 03 base model with an ECS supercharging kit and the car made 550 wHP and 487 wTQ with just those two Mods. The are reachable by phone also. I think they are the cheapest ones you can get. I dont believe in dumping as much $$$ into a car that I paid for it if its just a street car. If its a track car, thats a different story.
Good luck!
Old Aug 12, 2022 | 09:53 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Good luck!
This is the correct answer.
TPS Motorsports makes a good header, that's made in the USA too, and not as expensive as the Kooks or ARH.
The Speed Engineering are cheap, but fit great from many reports online. If they're all made from the same steel (304 stainless usually, some cheaper headers may use 409 which will rust), and the tubes are the same diameter, a tube is a tube is a tube, in my opinion.
Old Aug 12, 2022 | 11:13 AM
Beast's Avatar
Beast
I have LG 1 3/4. Have had them on since 2007, automatic trans. Headers make good power even if you don’t do other mods. No issues with my entire exhaust system since 2007. LG catted xpipe and bullet cat back.
Good Luck, you won’t be disappointed.
Old Aug 12, 2022 | 04:08 PM
Smoken1's Avatar
Smoken1
Good luck!
Did you have to remove the coil packs or the starter or the steering shaft to install the TSP headers?
And what did you have to do to figure this out?
https://www.corvetteforum.com/forums...n-problem.html
I had none of those problems
1 other question for ya, how much of the exhaust you need to take apart to change the starter since the are slip fit headers?
Old Aug 12, 2022 | 05:57 PM
vette4fl's Avatar
vette4fl
Whatever you can afford, and whatever will fit.
Old Aug 12, 2022 | 08:57 PM
partspusher's Avatar
partspusher
Did you even read the thread? They sent another header that fit better, not perfect but a lot better per the OP of that thread.
You're throwing a ton of questions and sounding defensive about headers man. Chill out chief. Some people can afford to do an extra 15 minutes, an hour of two of work, it's no big deal. I'd even say worth it to save a grand.
Old Aug 12, 2022 | 09:20 PM
dbgoodwin's Avatar
dbgoodwin
I ordered my xs-power headers back in 2013… I like them a lot, but honestly I wish I had spent a little more and gotten the best.
Old Aug 12, 2022 | 09:51 PM
Smoken1's Avatar
Smoken1
Yea I did read it, the OP asking about size and brand and I answered that ARH and Kook's are good headers and said that I have Kooks
I was just asking what 2003 Coupe had to do to install the TSP headers he was talking about being they are slip fit style header and also asking what all was involved installing those
As for time to do the work I have all the time I need as I am retired
Old Aug 13, 2022 | 12:12 AM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
Dont want to keep this going because it will derail the OPs thread but, I would order these headers again even considering what happened with them. I paid what I wanted to and the customer service that came with the product was satisfactory. I think your a bit of a creep for digging up such an old thread of mine and youre the only one who hasnt provided any constructive info for the OP. I remember most of your responses to my posts being mostly negative as well. Maybe you should sign off and go drive your car for a while so you can be reminded why were all here. Or try online gaming with the kids.
Sorry OP.
To what headers do yall recommend
Old Aug 13, 2022 | 07:42 AM
jdmvette's Avatar
jdmvette
Night Owl for life
ARH +1
Old Aug 13, 2022 | 10:26 AM
MSG C5's Avatar
MSG C5
Did you match up the Kooks to your stock axle back or do you have another exhaust system? Per my earlier response, I'm running a set of Corsa Indy Pros that have been on the car since 2004. Still running and sounding good, however since I'm planning to install some headers (with cats), I'm considering a new axle back as well and then retiring my Corsa and matching X-pipe. Do the 1 7/8 Kooks match up?
Old Aug 13, 2022 | 11:30 AM
garline14's Avatar
garline14
I personally have Speed Engineering headers, 2 and half years installed and have had no problems. I was surprised at how easy they were to install. Passenger side went in from the top, drivers side went in from the bottom. I left mine unwrapped but did wrap my starter with some heat reflective tape. I paid 415 shipped to my door. I went with new GM metal gaskets and bought new band clamps to help seal better. I just couldn't justify spending 1k plus or more on headers but that's just me.
