2000 Corvette
Old Sep 21, 2022 | 03:44 PM
Cunninge22's Avatar
Cunninge22
3rd Gear
Default 2000 Corvette
Does the shifter button have to be pressed to go from drive to neutral on a c5? Mine slides freely and I'm wondering if that is indeed wrong and what could be wrong with it.
Old Sep 21, 2022 | 03:48 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Welcome to the forum. That is normal. You DO need to push the button down to get out of park though.
Old Sep 21, 2022 | 03:54 PM
Cunninge22's Avatar
Cunninge22
3rd Gear
Yes still have to press it for park and reverse, I changed the shift cable and then when test driving if I put it in neutral it stayed in drive then put it in reverse and it was in neutral but once I pushed it up to park all the way then it would park and go back down the gears normally until I reached drive and then again same problem, I'm guessing my problem has to do with alignment of the cable and shifter apon reinstallation but I tried to fix that by pulling the cable all the way out and putting the shift all the way down to 1 and still got the same results
Old Sep 21, 2022 | 03:59 PM
MWWarlord's Avatar
MWWarlord
Yeah, that has to do with the shift cable. The car should definitely shift as labeled. Are you sure you got the right shift cable?
Old Sep 21, 2022 | 04:01 PM
Cunninge22's Avatar
Cunninge22
3rd Gear
Fairly sure the one I got pulled up for the Vette at O'Reilly's and is Delco brand but I didn't lay the old one out next to it to check exact size
Old Sep 21, 2022 | 04:29 PM
MWWarlord's Avatar
MWWarlord
I'm not sure what you did wrong. You may want to post this over in the C5 Tech section. Good luck!
To 2000 Corvette
