c5 oil filter
I stuffed in the clutch, killed the engine, and fortunately, I was close enough to home, that I could coast into my driveway. I was at a loss as to what to do, and it was kind of late in the evening, to do any trouble shooting, so I just left it. I was able to take my "winter beater" car to work the next day. After getting home from work, the next day, the first thing I do, is check the oil level, and it's completely full. Now what? I manage to wrestle the oil filter off, looking for anything strange, and see nothing. I grab another brand new filter off the shelf, fill it with oil, and install it. I disconnect the coil wire, so the engine won't start, and then hit the key to spin it over, and the oil pressure gauge goes right up to 10-15 PSI. I reinstall the coil wire, start the engine, the gauge jumps to 30 PSI, and the car ran fine for a number of years.
I never had any other issues with the engine, but after that, I did read a few articles about the marginal quality of the "standard" Fram filter, and I never bought another one. Was my experience tied to the filter, or some freaky mechanical issue? I'll never know........
I put a bowl under it, loosen it and let it drip and spin it off when the dripping stops
2. What is a middle splitter cable hack?
The cables on the middle air dam would keep breaking, so I came up with a solution with bolts, lock nuts and springs for the 4 locations.
There is a detailed description on a thread somewhere on this forum.
