ABS module relocation?
Old Nov 28, 2022 | 07:52 PM
hedg21's Avatar
hedg21
Default ABS module relocation?
If this has already been addressed somewhere please redirect me. I have a 2000 base coupe that I recently did a radiator replacement on and found that the ABS/ Electronic Brake Control Module is in an extremely inconvenient location. It seems that the drivers side fan actually contacts the module. In some of the videos I watched on removing the radiator it seemed the module wasn’t located in the same spot as mine. Has the module been relocated to a different spot in the later C5 years? If so is it possible to relocate the module on the earlier years to have better access to the fans? I literally fought to get the fan and radiator back in because of it. Thanks I’m advance.
Old Nov 28, 2022 | 08:01 PM
ThomasR's Avatar
ThomasR
The earlier cars had it mounted in the rear under the car.
Old Nov 29, 2022 | 09:20 AM
jackthelad's Avatar
jackthelad
'They were the very early cars, '97, '98's IIRC. The unit was moved forward prior to AH being available.
Old Nov 29, 2022 | 09:28 AM
Old Nov 29, 2022 | 09:41 AM
sonicss33's Avatar
sonicss33
Seems like it would be quite the effort for little return, meaning how many times do you plan on removing radiator and fans? I tend to ask these kinds of questions. Please don’t get offended.
Old Nov 29, 2022 | 12:11 PM
hedg21's Avatar
hedg21
no offense taken. It’s a logical question and honestly I don’t plan to do it often. It does make me interested in looking at aftermarket fans to see if they are slimmer.
To ABS module relocation?
