I'm sure this has been posted before, BUT, what is the most effective headlight bulb, best light, best overall usefulness and the best long term bulb ? There are Halogen, HID and LED bulbs, what has your experience shown to be ?
That's nice, but I'm only looking to get a better headlight/OEm type of lights, if I need to go LED do I need to get a resistor to be able to use the DRL function ?
Although I avoid driving at night, when I had to with the orighinal bulbs, it was scary. After reviewing post on the CF and remarks online about replacement recommendations, I replaced the low and high beams with SYLVANIA SOLVERSTAR ULTRA (#9005 AND 9006). A whole world of difference in illumination.
You can go this route, which is what I did, but the real problem is the sub par at best factory lense / reflector and no simple bulb swap can fix that. The only true safe and effective solution for night time driving is something like the Sharp Lighting Innovations complete replacement system. Their original system used halogen projectors, the latest version now uses LED projectors. The only other option is the near unobtainium GM export C5 glass lense headlamps which used H4 bulbs. And no sorry, the real true fix for the deficient factory C5 headlamp system is NOT inexpensive.
I bought a low and high beam set of LED bulbs, but I'm kinda put aside by the DRL being on, and this set of LED don't like to be a part of DRL, and I like having the DRL, so I have to look to the forum for some guidance. Now 'Vette-Lights' has a HID system which is Plug-And Play system and JHrinsin has a good point inlight is by how much you want to spend, and I'm not sure where to go at the present ?
If I were you, I'd follow the thread JHrinsin has linked. I also posted in that thread. If you're staying with the OEM lense, this is probably the easiest, and best way to go. If you can find them, Silverstar 9011 & 9012 HIR (Halogen Infrared Reflective) are the best way to go. I couldn't find them in Silverstar, so I got standard HIR 9011/9012. You must slightly trim one tang to match the 9005/9006 tangs, but it is an improvement.......
Ok, I don't want to go in that direction but the swap from the standard 9005 & 9006 over to the 9011 & 9012 seems like a affordable and safe option. Did you do anything else other than the trimming to get everything up, lit and completed, everything fit and all went back in OK no over heating problems ?
Thank you,
One other VERY IMPORTANT thing to remember is this:
ALWAYS wipe the glass bulb of any Halogen lamp with a paper towel, or small washcloth, soaked in rubbing alcohol, the higher %, the better. Do this last, after the bulb is mounted in the socket. Otherwise, the oil in your fingers will be deposited on the glass. This will cause hot spots, and shorten the bulbs life. I suppose brake parts cleaner might work, but I've never tried it.......
BTW.......Don't expect miracles from HIR bulbs. They do improve things, buy its not like a good, modern HID/LED setup. If I drove a lot at night, I'd ditch the factory lenses, and go with an HID/LED setup.....
Here is what I posted almost 4 years ago concerning the 9011/9012 swap and links to what others have said years earlier. Some of the links do not work anymore and the online store is now closed (the owner sadly passed away).
Hay JHrinsin, do these 9011 & 9012 Do they burn hotter than the halogen bulbs ? Whenever dealing with something electrical I always tend to worry about heat ? Oh, what kind of modifications do these 2 bulbs need to fit the 9005 & 9006 holders ?
I don't drive the Vette much at night. I have other cars for that.
Spending a lot on lighting was not an option. A set of LEDs with resistors solved my lighting problem. They are bright and plentiful for my purpose.
As far as blinding other drivers, this has not happened to me. The car is low enough for it to be a non issue.
All new cars have blinding LEDs in them anyway.
I understand there are haters of LEDs in OEM housing, but they work for me and I have never bothered anyone coming the other way.
Ok, what did you use as far as LED's There are so many on the market, I'm trying to keep the lumens as high as possible, but again I'm not too sure if that has that much bearing on LED's. I'm trying to get the best high output light within OEM application ? if i'm stating it correctly ?
Thank you,
I used Vette lights kit and added the Fog lights. I think it was $ 99 for the headlights + $ 69 for the fog lights. I Also did the high beams while I was in there, but I have never used them. I don't recall the price on them. 1997-2004 C5 Corvette High-Powered Low Beam LED Kit – Vette Lights (vette-lights.com)
There may be better options out there. There were partially plastic with a good and quiet fan. I would like to have used a single piece all metal housing. they're out there.
The Fogs don't have fans if I recall. If I am mostly driving at dusk or dawn, like I typically do, I run on the fogs alone and they give plenty of lights. Past that, I use the headlights.
Their description says 12k lumens. Total price was $ 259.00 for all three but honestly, I wouldn't do the high beams. Waste of money.
I experimented with LEDS and HIDS, and was not happy with the light output. The lenses are the problem. If you bite the bullet and spend the money for the Sharp Lighting Innovation assemblies you will be happy with the results. The difference is like night and day. Expensive but worth the money and effort. IMO.
