Column Lock Bypass
Old Jan 1, 2023 | 01:08 PM
Sunset Kev's Avatar
Sunset Kev
6th Gear
Default Column Lock Bypass
What is the best column lock bypass to use.
Old Jan 1, 2023 | 01:45 PM
Johnny Hardcore's Avatar
Johnny Hardcore
LMC5 by Complianceparts.com is the best.
The extra step of the "Brown Wire mod" is typically necessary for a complete 100% bypass to correct all issues with "pull key wait 10 seconds" error.
Old Jan 1, 2023 | 05:29 PM
41bigdawg's Avatar
41bigdawg
Definitely the LMC5...put it in and never worry about it again
Old Jan 2, 2023 | 12:35 AM
I ran one of the original column lock bypass devices on two of my C5s, but if I were going to install one now, it would be an LMC5.
Old Jan 3, 2023 | 03:20 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
People have tons of problems with the LMC5. The original CLB is much more reliable and is discounted right here on the forum.
https://www.corvetteforum.com/forums...post1606102525
Old Jan 3, 2023 | 05:56 PM
wrmiles's Avatar
wrmiles
I only had two problems, neither the fault of the LMC5. Had a difficult time getting the column unlocked with the unlocker (had to remove the steering column shroud and tap on the lock with a screwdriver and hammer, per Richard's advice) and I got one of the LMC5 pigtails 180 deg out in the mating connector.
Old Jan 3, 2023 | 06:50 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
I dunno... the LCM5 is has been the Bullitt proof, "go to" for a long time. The "People with tons of problems" are awful quiet.
Old Jan 3, 2023 | 07:12 PM
ztheusa's Avatar
ztheusa
Then why do so many owners have to "call Richard?"
Old Jan 3, 2023 | 07:23 PM
Johnny Hardcore
Because they can't follow directions.
Old Jul 15, 2025 | 08:40 AM
VRYRED's Avatar
VRYRED
Default LMC5 2000 vette
Hello
I just had this installed to correct the Pull Key code. It unlocked the steering wheel as required but now I get the Pull Key message.
Nobody i have spoken with can help me with this problem. Hopefully someone here know the fix.
Thanks in advance.
Doug
Old Jul 15, 2025 | 10:07 AM
rrwirsi's Avatar
rrwirsi
Did they do the "Brown Wire" additional install suggested in the instructions? That install usually corrects the pull key issue.
To Column Lock Bypass
