Techron
Old Aug 16, 2023 | 07:06 PM
walleyejack's Avatar
walleyejack
Default Techron
good evening.. I am heading to the Woodward Dream Cruise this weekend in Detroit area, am wondering if there are any stores have Techron on sale or at least a good price. I have looked and see nothing too exciting, my searches are usually useless. Is not available north of the border.
Any help would be appreciated.
TIA
Al
Popular Reply
Aug 16, 2023, 08:21 PM
DDaaryl's Avatar
DDaaryl
Originally Posted by Corvettemanual
Techron is the biggest myth in the corvette world. If you think you need Techron aka your gas gauge isn’t working properly, it’s already too late. You could put bourbon on your tank and it won’t clean the sender. Spend the $500-750 and just get new senders.
On my 2002 vert the gas gauge failed and I added Techron. Within two miles the problem was resolved. I added a bottle every six months after that. Three years later the gauge acted up again. It took two doses and almost 100 miles before it solved the problem. Removing the sending unit was never an option for me. Techron is magic. Use it!
Old Aug 16, 2023 | 07:16 PM
Corvettemanual's Avatar
Corvettemanual
Banned Scam/Spammer
Old Aug 16, 2023 | 07:28 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I agree with the new guy. I nibbled on the bait for a month or two many years ago and it never would have fixed my senders. Nor do I believe in using it as a preventative maintenance item.
That being said if people want to pour that stuff in by all means.
Old Aug 16, 2023 | 07:30 PM
Corvettemanual
Banned Scam/Spammer
Dont under estimate “new guys”. Sometimes they know a lot. 🤣
Techron is a waste of money
Old Aug 16, 2023 | 07:54 PM
Mr. Black's Avatar
Mr. Black
I've been sitting here for 20 minutes trying to figure out who this could be lol.
Old Aug 16, 2023 | 08:21 PM
DDaaryl's Avatar
DDaaryl
Old Aug 16, 2023 | 08:29 PM
Corvettemanual
Banned Scam/Spammer
I had a gas gauge acting up. Spent $125 on multiple Techron uses over several months and fill ups. Zero results. Replaced the senders. Fixed issue immediately. We all have different experiences. If one bottle doesn’t fix your issue, it never will. Don’t make my mistake!
Old Aug 16, 2023 | 08:30 PM
walleyejack
i don t need or use it for fuel senders
Old Aug 16, 2023 | 08:32 PM
walleyejack
does it really matter how i spend my money ?
sorry i asked this questions.
Old Aug 16, 2023 | 08:37 PM
Corvettemanual
Banned Scam/Spammer
most people do
Old Aug 16, 2023 | 08:38 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Using a bottle of Techron now and then will hurt nothing, it does more to help than not. I run a bottle a month.
I’ve read enough threads of folks who have seen a fix for their fuel senders with Techron where it’s worth a try.
Here’s some “science” behind the benefits the Techron:
Old Aug 16, 2023 | 09:21 PM
jcgunn's Avatar
jcgunn
Come on guys, our friend from north of the border is just looking for a good price on a product lots of us use. OP, check Autozone and O'Reily, they often run BOGO deals on Techron. None advertised as we speak, but maybe when you are down south visiting.
Old Aug 16, 2023 | 09:47 PM
hyperv6's Avatar
hyperv6
Results often depend on what is exactly wrong and how far gone it is.
Best it is said it is a preventive and if you have a sender issue your results may very. In some cases it will not fix thing but in others it will. Not ever case is the same.
Running it as a preventative is not going to hurt a thing if you can’t get the top tier fuels in your area.
I used to think Marvel Mystery Oil was an old man’s myth but when I freed up a Corvair engine that was sitting for 25 years I realized it does work. Now I know it is not a cure all for all but it does work in some cases.
Most don’t need Techron because they already use good gas.
Old Aug 16, 2023 | 10:15 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Had sender contamination after setting all winter, two different times. Cured the problem both times. Actually, read about techron usages in a porsche magazine. Back in 1988 when I had a porsche. It works for me.
Old Aug 17, 2023 | 08:37 AM
YMMV, but I have used Techron for years and never had a fuel sending unit go bad. Does it mean the sending unit would have gone bad without using Techron - can’t say that for sure. For around $30/year for two bottles of the stuff (one bottle every six months), I’ll take my chances with it.
If you think it is snake oil, that’s OK - it is your money and your car. Too many owners have posted here on the forum that it works to be a total waste of time, IMO.
Old Aug 17, 2023 | 08:55 AM
Black 03 Z06's Avatar
Black 03 Z06
@walleyejack Al, you can buy it in Canada off Amazon.CA. A friend on the Rock was having issues that Techron was supposed to cure, it actually worked. His (fuel sender) problem disappeared.
Old Aug 17, 2023 | 09:52 AM
rrwirsi's Avatar
rrwirsi
After buying the 2004 C5 in 2014 and reading about the sending unit problem, I used the 'snake oil' at every other fill up of Shell Premium. About 4 years later, my fuel gauge started acting up. No amount of additional snake oil solved the problem. The gauge now will drop to empty after fill up. However, in about 15 miles of driving it will return to reading properly. Because I would have to drop the tanks to replace the sending units, I decided I can live with issue. Just another C5 part quality control and fuel tank design goofs by the GM.
To Techron
Old Aug 17, 2023 | 10:18 AM
grinder11's Avatar
grinder11
I agree....somewhat. Techron DOES help......SOME fuel senders. BUT, on the other side of that coin, if it works, it's only a matter of time before it wont. So you're correct, its probably too late. Also, with the price of C5 sending units, after using 8-10 bottles of Techron, you've spent enough to pay for the new senders. I'm one who spent more than the senders cost. If I'd known they were relatively cheap, I'd have gone with new senders from the beginning. I can see that it is certainly worth trying is on the '03-'04 C5s that have to drop the tanks (drivetrain?) to change. I just did this job on my 2000, and if it weren't for a mental mistake I made, it was actually pretty easy and straightforward. Thanks to @Mr Black and @spfautsch . With a small cleanup of that thread, it would make a great sticky........
Old Aug 17, 2023 | 10:32 AM
grinder11's Avatar
grinder11
TIA
Al
OP, I don't know if you've ever been to Woodward before. If not, and I'm not trying to rain on your parade, be aware that, like many things, it has become so commercialized that I no longer go. It is more of a "park" than a cruise. Many times it takes 20 minutes to over a half hour to travel 1/2-3/4 mile!! I live here, and have been many times. Today, it's better to watch from a lawn chair than "cruise." If you go 40 miles North to Flint, the "Back to the Bricks" cruise, held the same week, is better, in my opinion. Many may not know it, but Flint is where GM began, along with the 1953 Corvette. Enjoy your stay!!! My .02, YMMV......
Old Aug 17, 2023 | 10:35 AM
jackthelad's Avatar
jackthelad
I used to have a problem with my '98 (had it from new), the gauge would drop to zero after a while - turn off and on again and all OK. There was a computer update that fixed it for me back around 2000 or so. Some kind of error recovery was added to the programming. Never had the problem since. Used Techron occasionally but if you use Top Tier gas, you should not need anything else.
